Old 08-05-2004, 01:25 PM
haus01 haus01 is offline
99 tahoe braking problem
I have a 99 tahoe 4wd, a few months ago the brakes became soft so when braking at high speeds they seem fine, but when stopping at a red light or braking at slow speeds the pedal goes to the floor and the abs kicks in. I just changed the front pads, rotors, calipers, caliper bolts/sleeves ( I greased the sleeves,hope your supposed to!) and changed the fluid and bled all four brakes. Still have the same problems when coming to complete stop with the abs kicking in. Any suggestions??
thanks
Old 08-05-2004, 09:35 PM
95silverado 95silverado is offline
Probably the master cylinder, if the brake pedal goes to the floor.
Old 08-05-2004, 10:35 PM
Pakeboy2's Avatar
Pakeboy2 Pakeboy2 is offline
Send a message via AIM to Pakeboy2
Re: 99 tahoe braking problem
You need to bleed your brakes about 4 times...pedal is stronger!
1999 Chevy Tahoe LT 4 dr.<---got flooded out/totaled
Now we have a 1999 Chevy Suburban LT, same color and
interior as the Tahoe, just 22 inches longer, has the 3rd seat and a BIGGER gas tank
1995 Honda Passport 2 whl dr.
1992 Mazda Protege DX-5 spd.
2005 Keystone Outback 21RS
~~~HAWAIIAN STYLE~~~
cardomain.com/memberpage/621985
cardomain.com/memberpage/643906
weedlesswillie.com
Old 08-06-2004, 06:35 PM
I was thinking the master cylinder also...is this something a semi intelligent mechanic can do or should I take it to a garage?? any special tools needed?
thanks
Old 08-06-2004, 06:53 PM
It's not hard to change, but you will have to bleed the brakes again, after you change it.
