Old 08-05-2004, 02:10 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
turbo questions
i have a few questions were and what do i do with blow off valves. and how much boost should i let into my stock d15b1 to keep it from frying
Old 08-05-2004, 05:37 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
as long as ur motor is in fine running order...i would say about 6-7 psi...no more.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 08-05-2004, 07:18 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Blow off valves, you only need one, and it should be installed probably 6-12inches from the throttle body.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 08-05-2004, 09:12 PM
Re: turbo questions
well what about on on the manifold i see those once i na while. and how would i work the blow off vavle to make sure i dotn get to much pressure into my engine
Old 08-05-2004, 10:25 PM
91civicDXdude's Avatar
Re: turbo questions
a blow off valve releases pressure in the charge piping when a sudden vacuum condition exists, such as shifting or letting off the gas. it is automatic, controlled only by equal vacuum forces on both sides of a spring actuated pistons.
You are thinking of a wastegate. A wastegate controls boost by bypassing the exhaust flow from the turbine once a predetermined boost level is met, which works on a spring principle as well.
Old 08-06-2004, 12:31 AM
Re: turbo questions
so were does the waste gate go and were does the blow off valve go
Old 08-06-2004, 12:59 AM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
Re: turbo questions
Not steal you thread or anything. but what gauges would you recommend for a turbo set up?
My Name is Roberto AKA. Berto
Old 08-06-2004, 01:24 AM
Re: turbo questions
i reccommend a boost guage
Old 08-06-2004, 01:33 AM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
Re: turbo questions
have you done your research lately? im sure there are lots of write up on turbo setups.
the waste gate on the manifold or turbo.
the blow off valve, i think someone up there said charge pip. you can place it somewhere near the intake manifold, dont get 2 close, most people place it around 2 to 4 ft away from the intake.
Old 08-06-2004, 01:51 AM
Re: turbo questions
other then a boost gauge
Old 08-06-2004, 02:29 AM
Re: turbo questions
on the guage, if you want a light show get a air/fuel ratio but a lot of people may say they're practically useless. I have no clue if that b1 is vtec = if it is, get a vafc, if not safc. and dont use the stock injectors. people may even tell you to look into fmu's.
I suggest before jumping into a boost setup get to know your car first and everything inside out with it; make sure its running good. When your in boost life will be easier when you encounter issues. I also think you should really, TRULY learn about boosting before you do it. get a clue for what your about to do to your car and what it will do to your car before you do it. But if you have money to throw away, then learn the hard way.
Old 08-06-2004, 08:27 AM
Re: turbo questions
first off, FMU's are crap, and if you use an FMU, you generally use it in conjunction with *stock* injectors. running an FMU with larger injectors will consist of the car not running, and in the even that it will idle properly, then hell has frozen over, and the car will run like crap in the top end becuase of the larger injectors *PLUS* highly increased fuel pressure.
i will agree with itechengineers on one point... research it before you do it.
*ENGINE MANAGEMENT SHOULD BE YOUR #1 PRIORITY WITH A BOOST SETUP*
Old 08-06-2004, 07:22 PM
Re: turbo questions
can you run hondata? or would reccomend uberdata
Old 08-06-2004, 08:41 PM
Re: turbo questions
ECU modification gets 2 thumbs up from me.
