Old 08-05-2004, 12:36 PM
lvdennis's Avatar
lvdennis lvdennis is offline
Cracked Power Brake Booster Stud
Is it possible to replace a cracked stud on the power brake booster (master cylinder side) .......? Or any way to "re-attach" it safely? The booster works fine, except for the bolt issue pushing the master cylinder...
Thanks...
Old 08-06-2004, 07:39 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Cracked Power Brake Booster Stud
Exactly what part is cracked? Is it one of the 2 studs that holds the master cyl on, or is it the pushrod, that pushes on the plunger in the master cyl when you step on the brake pedal?
For the stud problem, try this thread: http://www.automotiveforums.com/vbul...d.php?t=268722
If its a pushrod problem, I suggest a new or professionally rebuilt brake booster.
