Old 08-05-2004, 11:06 AM
BB1970's Avatar
BB1970 BB1970 is offline
Unhappy Peak And Hold Ebc?
peak and hold electronic boost controllers.....
do they work? do they hold boost to redline?
any makes better than others?
got a mbc on mine and im fed up with my boost falling back...
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 08-05-2004, 01:12 PM
Hotshot8792 Hotshot8792 is offline
your boost falls back because you are on stock turbos
stock turbos dont flow enough air to only hold about 10-12 psi to redline
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 08-05-2004, 01:51 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: Peak And Hold Ebc?
hey hothsot, if that is true than my reason for the hesitation makes even more sense now. i have my boost controller set to hold 12-13psi to redline, by adjusting my gain. if i drop my gain and raise my boost, maybe i won't get the hesitation anymore.
why the hell didn't i think of that in the first place
Old 08-06-2004, 04:05 AM
BB1970's Avatar
Appreciated, but to maintain 10-12 psi on my mbc i have to set my boost at around 15-16psi to allow for the drop in boost, i.e for a fraction of a second the turbo's are spooling up to around 15-16psi which according to most theories is too much boost for our stock fuel system is this correct and dangerous?
blitz dome filter
sachs clutch
Old 08-06-2004, 11:08 AM
Re: Re: Peak And Hold Ebc?
yes, its dangerous to run that much boost on stock turbos, i would not go above 14.5 psi. If your having to run that much boost to hold 10-12 psi to redline, it means you have a boost leak somewhere, and it would be better to try to find the boost leak then try to overboost your turbos, because after 14 psi, the stock turbos generate a lot of heat which is bad.
Youngvr4, i'm taking it you have an electronic boost controller. Gain is the setting to control how quick your wastegates react, which should be set at or around 5, maybe up to 7. Then raise the boost up by ratio or whatever your setting is.
Old 08-06-2004, 02:31 PM
youngvr4's Avatar
STREET RACING GURU
yeah its a ebc, but this thing goes by percent. and i'm guessing 0-100, you mean to tell me i should have it on 5-7 percent?
and also when i raise the gain, it does seem to hold psi longer then when its turned down
Old 08-06-2004, 02:55 PM
Skyline_R32_Canada's Avatar
Skyline_R32_Canada Skyline_R32_Canada is offline
do you have a peak hold function on yours? i think its there to hold the wastegate shut as long as possible (and not make any boost spikes at the same time)
not sure if thats its soul duty though
Old 08-06-2004, 04:15 PM
youngvr4's Avatar
STREET RACING GURU
so when the wastegate is open it holds peak? or visa versa
Old 08-06-2004, 04:54 PM
i think when the wastegate opens its past peak hold because when it opens it lets out the exhaust gases so it doesnt produce more boost
