Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-05-2004, 10:40 AM
PK55 PK55 is offline
Send a message via AIM to PK55 Send a message via Yahoo to PK55
Unhappy 1987 Camry Running Rough
This is a great forum...thanks for any help you can offer guys..
Ok 1987 Toyota Camry...out of nowhere it lost some power.
You can hear it running rough after you fire it up. It runs so rough that it sounds different coming out of the muff...sounds like one of those after market street racing mufflers...LOL...higher pitched...
The car shakes when accelerating and moves slow into acceleration. While it will eventually accelerate and get going the rattling is always there. Even on the freeway you can hear the engine dip down a little with loss of power.
Tried testing the plugs and when I removed the cap for each one while running there was a noticable loss of power again like there should be.
The black connector tubes that connect the wires to the plug in two of them had a little moisture. One more that the other. Could it be the seal?
Hmmm...any help would be appreciated before I tear into it...
Old 08-05-2004, 02:44 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Re: 1987 Camry Rough Running
This is a possibility that it could need new spark plug tube seals...especially since you said there was moisture on the plug. You also might want to check the distributor, rotor button, and cap...just to make sure everything's in top shape. Also, you may want to pull the plugs and check their condition as well.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 08-05-2004, 02:46 PM
The moisture was actually on the balck tube on the OUTSIDE...it connects to plug wires and covers and seals the connection to the spark plug.
Old 08-05-2004, 07:16 PM
300+ 300+ is offline
Have you checked the timing. Timing belt may have jumped, ready to break.
Old 08-06-2004, 08:46 AM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
have a muffler shop check for plugged muffler or catalytic converter, or you can attach a vacuum gauge and see whether vacuum drops at steady engine speed.
internally collapsed component in exhaust will result in power loss.
Old 08-06-2004, 09:37 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
I vote for plugged Cat. Converter or muffler.
Old 08-07-2004, 04:50 PM
Thanks guys for giving me some options to check out...I'm gonna try the muffler shop first...
peace
Old 08-18-2004, 08:45 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Timing belt slipped on my 87 Camry several years ago. Timing went to 40 deg BTDC. Produced s..l..o..w acceleration, vibration, and bad pre-ignition(pinging=rattling?).
