Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-05-2004, 08:20 AM
indyram indyram is offline
Leaking oil
My truck has been leaking oil lately changed pcv valve. Gaskets and everything look fine can find a source any ideas. It's a 1996 ram 5.9L.
Thanks
Old 08-05-2004, 05:29 PM
LTJGWorth's Avatar
LTJGWorth LTJGWorth is offline
Re: Leaking oil
If you know it's leaking oil, can't you just trace it back to the source?
Old 08-05-2004, 06:26 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: Leaking oil
Yeah, can you see it coming from somewhere? If it's making a puddle, where is it underneath? Front seal maybe?
My Mopars
Old 11-20-2004, 01:13 PM
CT McGuire CT McGuire is offline
Re: Re: Leaking oil
answer to your question.i have an oil leak also and can't find the source.it is like it is leaking internally.i did pull the breather off to find oil in the throttle body.can anyone help with this problem.the oil seems to be burning off through exhaust.
Old 11-23-2004, 09:51 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: Leaking oil
are you noticing any spark knock(pinging) when the engine is under load(taking off, or going up a hill)?
open the throttle blades, and shine a light down through the throttle body and look into the intake manifold, if you have oil in there, there is a good chance that your plenum gasket has blown.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 11-27-2004, 02:40 AM
Re: Leaking oil
I have replaced the valve cover gaskets and have looked in about every conceivable spot that I can think of and can't find the source. There is no problem with mpg or power.
Old 11-27-2004, 11:23 AM
BleedDodge's Avatar
Re: Leaking oil
Do you mean it's leaking oil so that you see a puddle, or oil accumulated on a certain part? Or do you mean that when you pull the dipstick every so often there is oil missing and you think it's leaking? Maybe the motor burns lots of oil, I don't know what you mean by "leaking oil"...
My Mopars
