Old 08-05-2004, 02:25 AM
TheCatcherESM TheCatcherESM is offline
Post I hear clicking when I turn left or right, what's wrong?
Whenever I make a turn I hear loud clicking. Once the car started vibrating a bit and it was hard to steer in the direction I wanted to go. It stopped and now only clicks. I was wondering what happened and what's wrong?
Old 08-05-2004, 02:54 AM
khmerboy khmerboy is offline
Cv boots
Your cv boots on the axle must be torn. You can either replace the whole axle or just the boot. I just replace the boot on mine. It cost me about 40 dollars to do both sides. I think if you replace the whole axle it will cost maybe 70 and up I think. Here is a site that will help you in replacing the axles, if they are in fact the problem. http://www.honda-tech.com/zerothread?id=382416
Old 08-05-2004, 12:29 PM
Re: I hear clicking when I turn left or right, what's wrong?
Thanks for the info. That site is GREAT! Thanks for passing it along. You have any clue how long you can drive around with a cracked axle and what safe speeds are?
Old 08-05-2004, 12:52 PM
~ls/vtec~'s Avatar
~ls/vtec~ ~ls/vtec~ is offline
Send a message via MSN to ~ls/vtec~
i wouldnt recomend driving the car at all untill u fix the problem. one problem could lead to another
Old 08-05-2004, 08:11 PM
Your axles I think are pretty bad since you had a hard time steering. So I wouldn't drive it until you get it fixed. The axles might fail and leave you stranded. I think it depends on how strong your tranny is or how hard you drive it. My friend put in a racing clutch, stage six I believe, took it out to test (with torn boots) and it actually ripped the boot in half leaving the axle hanging from the transmission. We had to push the car back to the house. Lucky we weren't going high speeds. Well glad to be of help.
Old 08-06-2004, 04:31 PM
boomersoonercivic boomersoonercivic is offline
you can drive it, but it will cause unneccesary strain on the car. you can drive it all the way til it completely breaks and since yours is fwd it wont drive what so ever. it happend to mine once, had to call AAA to tow me.
Old 08-06-2004, 10:29 PM
02HondaCivicEX 02HondaCivicEX is offline
My car makes a very quiet clicking sound when I make sharp L or R turns, do I have the same problem?
Old 08-06-2004, 11:36 PM
Probably. Lift up your car and take a look at the boots. If torn and leaking grease, then the answer is yes.
Old 08-07-2004, 04:17 PM
MunG35's Avatar
MunG35 MunG35 is offline
Send a message via AIM to MunG35 Send a message via Yahoo to MunG35
i get the same clicking only mine is when the a/c or the fan of the a/c is on. when i turn the a/c off, the clicking stops. also, this problem comes when i acclerate hard or brake hard. any ideas?
Are stock tips worth anything? See how the experts do: http://www.stocktiptrader.com
Old 08-07-2004, 06:31 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Your have a bad/worn CV joint. The CV boot is probably torn too. If the boot was torn and it didn't click, you could probably just have a new CV boot put on and be good. The clicking idicates that contaminets have gooten inside the CV joint and ruined it. You'll need to have your CV jpints replace, which is done by getting a new axel. I wouldn't drive around until you get it fixed.
Although normally it doesn't get this bad before it is fixed, I know of one case where a guy in here was driving around and it just snapped at the CV joint. He let it go to long.
Also, the the 2nd guy in here who asked "my car makes the same sound do I have the same problem", if your car makes the same sound when you turn, you probably have the same problem.
