Old 08-05-2004, 01:04 AM
blowemupbob blowemupbob is offline
92 ford escort starting problem
i have a problem with my wiring. the car will crank but i dont hear the eec relay turn on which means no fuel no fan. i need to know where the power goes from the ignition switch before it goes to the relays? i was getting my escort fitted for a roll cage for racing and someone took out the ignition box. when i tried to hot wire it the eec relay wires were cut and started arcing so i pulled them apart to stop it and now i have to run power from the battery to the relays to get my fan and fuel pump on. the problem i have with this is arent there different speeds at which the pump operates? also if i run dirrect my alternator doesnt work . car dies when battery disconected. i need a wiring diagram if someone has one please
Old 08-05-2004, 03:47 PM
92EscrtPmp 92EscrtPmp is offline
Re: 92 ford escort starting problem
sounds like the timing. the 1.9's had a Timing Fuse
Old 08-05-2004, 03:49 PM
My friends 1.9b Doesn't even have the EEC crap on it... completely bypassed. actually all his has is enough to crank the thing and get the dash to work.
