Old 08-05-2004, 01:04 AM
EbayCR-X EbayCR-X is offline
Where to run Power Cable on a 90 CRX Si?
Hi everyone. does any have experience installing an amplifier in a 90 crx si? i cant seem to find the spot to run my power cable through the firewall into the cabin. my integra install was a snap but this one is killing me. if possible i'd like to know the exact location any of you have used, also i will be using 4g wire in the install.
Old 08-05-2004, 01:14 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Where to run Power Cable on a 90 CRX Si?
right above the ecu is where I ran mine, 4g also. There is a hole it will go though, next to a bunch of other wires.
Old 08-05-2004, 01:18 AM
should i remove the ecu to expose the hole?
Old 08-05-2004, 03:56 AM
V-K V-K is offline
Send a message via AIM to V-K
I ran all of my wires through the hole where the A/C used to be. Don't know if the Si's have the same hole though...
Old 08-05-2004, 03:26 PM
Forunn Daberator
no, the hole is above the ecu, should be able to see it when you pull the carpet back. mine is a DX but the firewall would be the same.
