Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 08-04-2004, 10:02 PM
rongrzywacz rongrzywacz is offline
can't turn key off - 94 bonnie
Help,
I've got a 94 Bonnie, that I can't turn off. The key will no turn past the on position. I had to disconnect the battery to turn it off. Any ideas on what the problem could be? I can usually fix anything, but don't know where to start here. I have pulled sterring wheels in the past.
Any idea on what it would cost to have fixed at my local garage.
Thanks for any help.
Ron G.
Old 08-04-2004, 10:25 PM
DOpey85's Avatar
DOpey85 DOpey85 is offline
Send a message via Yahoo to DOpey85
This sounds like it could be an easy fix... Make sure that you have a shifter all the way in park... Is the steering wheel locked? If it is then just try to move the steering wheel back and fourth... Those are the only two ways I can think of to fix it... If they don't work and you'll have to take it somewhere. I don't know what it would cost, but just hope that they don't have to disassemble the steering colum or it will be expensive.
Car owners from the Midwest Hit up this forum, and sign up we are in need of more active members to take part in out discussions
MIDWEST MADNESS!!!!!!!!!!!
Old 08-04-2004, 10:39 PM
Re: can't turn key off - 94 bonnie
No the steering wheel is not locked. It is still in the on positon. And it doesn't seem to mater what gear it is in. I don't think it had to be in part to turn the key off.
Old 08-04-2004, 10:50 PM
STINKINLINCOLN's Avatar
STINKINLINCOLN STINKINLINCOLN is offline
Send a message via AIM to STINKINLINCOLN Send a message via MSN to STINKINLINCOLN Send a message via Yahoo to STINKINLINCOLN
your right the car does not have to be in park to turn the car off is this the first time that it has happend is this the second set of keys ?
can you take the keys out ?
and last of all did you use the right set of keys lol
let me know
93" LINCOLN CONTINENTAL
69" BUICK RIVIERA
1988 MAZDA B2200NEEDS HELP
http://www.geocities.com/jjbannon81/69RIVIERA.html
1999 OLD ALERO
Old 08-05-2004, 07:04 AM
Yes, this is the first time that this happened and they are the orginal keys. No I cannot take the key out.
