Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-04-2004, 09:40 PM
SHUSHU SHUSHU is offline
A/C and Cruise control
I have a '96 RAM 1500, w/318. With the A/C blowing, When I accelerate, the dash vents quit blowing. When I let off the gas, they come back on. Also, my cruise control will notengage/work. I replaced the check valve to no avail. I've been told that the problem is related to both the A/C and Cruiw control. Can anyone tell me what the problem might be?
Thanks, Frank
Old 08-05-2004, 12:07 PM
dirty dan dirty dan is offline
You've got a vacuum leak. It's a real pain, but you're going to have to track down your vacumm lines and check them all. It's easiest to start at the vent controller and work your way back.
Old 08-05-2004, 04:27 PM
LTJGWorth's Avatar
LTJGWorth LTJGWorth is offline
Re: A/C and Cruise control
The most likely problem is in addition to the vacuum lines. You won't be able to find the stock one's unless you really feel like looking long and hard for them. Go to someplace like Autozone and buy the small rubber hose and you can use it with your old one and make it work. Also, there is a cruise control servo underneath your battery that is prone to having battery acid spilled on it and eating it away. Trust me, I know because I replace my vacuum lines and thought that would fix it but it didn't. I ended up having to replace that servo because of a large hole that had been eaten through by the acid. The part is about 30-40 bucks from a mopar dealer. Sometimes you can get one from ebaymotors (where I got mine for $13.50). You won't be able to find it at Autozone or Advance or any place like that.
Old 08-15-2004, 03:50 PM
duke0090 duke0090 is offline
Thumbs up Same Problem
Hi SHUSHU I have the same exact problem you have. If you find a leak or have allready fixed the problem please reply back. Im fixing to work on mine right now and see where I can get. Thanks and keep me posted
Old 08-17-2004, 06:42 PM
LTJGWorth's Avatar
Did I mention I have pictures of the part? I have pictures of my old one with the hole in it and I can take pictures of my new one and the location of it in the truck.
Old 09-07-2004, 07:38 PM
mikeinsurprise mikeinsurprise is offline
I am having the same problem with my 2001 Ram 1500. I will try to find the vacuum leak. If anyone else has found the same problem could you let me know so I know what vacuum lines to look at first.
Old 09-07-2004, 07:50 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Check all of the vacuum lines, it's the only way.
My Mopars
Old 09-07-2004, 08:05 PM
TurboSW's Avatar
TurboSW TurboSW is offline
Yes I had the same problem with my 96 and these guys helped me out. There'a another thread with all the info you need. Just look through the 1st couple of pages here.
Old 09-08-2004, 04:49 PM
LTJGWorth's Avatar
It's always the one vacuume line and cruise servo. So far, everyone I have talked to has said thats what it is. So far is has never been anything electrical.
Old 04-28-2005, 09:02 PM
pissedriteoff pissedriteoff is offline
The Fix Is The Vacuum Line Going To The Gizmo Under The Battery...i Had No Cruise Or Air Until I Found What I Read Here, A Broken Vacuum Line...added Some Line And Sure Enuf The Problems Are Fixed...thanx Guys
Old 04-28-2005, 09:43 PM
troy1 troy1 is offline
AF -Advisor
Does any one know if this holds true on a 95 dakota 4x4 V8 mine does this also every now and then.
