Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 08-04-2004, 01:35 PM
Stevomr2Turbo Stevomr2Turbo is offline
Install blizt tt... whers the vacuum hose for boost?
hey.. i just installed my blitz dtt and it has boost gauge, peak hold display, and boost warning function .. it says in the instructions" connect vaccum tube to a source behind the throttle body. Use the supplied ocnnector. "t", and hose." but i'm not sure which hose i'm suppose to tap into.. is it the vacuum hose coming off the bypass valve? Going by hoses.. none of the hoses looked to b the same size as the one supplied ne how.. so i have no clue.. ne help would b greatly aprreciated.. thanks, steve
Old 08-04-2004, 03:29 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: Install blizt tt... whers the vacuum hose for boost?
Do NOT touch the hoses on the OEM BPV.
The easiest place to tap into is the MAP (manifold presure sensor) ... otherwise known as boost sensor.
It is on the trunk/engine compartment firewall.
It is on the passenger side.
It is nest to the little box that says "Diagnostics" on top of it.
The sensor will have one vac line going to it.
You can T into that.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 08-04-2004, 05:52 PM
thanks man.. i would have never thought to look there for it.. and this brings me to my next question.... is there an easier way to route it thru the car without drilling thru the firewall.. i looked around but i didnt' c an easy way. Maybe by the clutch cables that go thur the middle, theres a rubber boot.. but i could hardly get my screwdriver thru there, so i don't think it would work.. ne ideas? thanks again
Old 08-04-2004, 07:04 PM
AF - Advisor
Between the seats, I am assuming you have the CD Storage box? .... there is a hole to the engine bay behind it. Just follow your shifter cables
Old 08-04-2004, 07:31 PM
hmm..i'll give it another go tomorrow. and c what happends.. it looks hard to get the tube thru since thers a heat shield on the other side it looks like. thanks for ur'e help
Old 08-04-2004, 09:32 PM
AF - Advisor
If you poke enough hose through ... you can get the hose to peak out of the heat shield.
