Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 08-04-2004, 10:07 AM
dhspring dhspring is offline
Fuel Pump problem
My fuel pump went out at 56,000 miles and now at 60,000 miles the same thing seems to be happening, which is that the engine seems starved for fuel. It doesn't die, but it's hard to start at times. The fuel filter has been changes and pressure test on the fuel pump tell us the check valve is functioning. Has anyone seen this type of problem with their Yukon?
Old 08-05-2004, 03:25 PM
badlanz badlanz is offline
I've heard the fuel pumps go out sooner than they should, but when fixed, problem solved. Not sure what to tell you. What it cost to replace the pump may I ask? I'm waiting for that big moment.....pulling a boat, heading on vacation and then stalled engine, vacation over. Maybe should have it replaced before it does happen.
Old 08-05-2004, 04:11 PM
Re: Fuel Pump problem
I actually posted this for my friend who owns the Yukon, but I think it's around 7-$800 to replace about any fuel pump where the tank has to be dropped. It's pretty steep. A preventative replacement wouldn't be a bad idea since it'll probably have to be done sooner or later, and you certainly don't want to have to do it while on vacation or long trip.
Old 08-05-2004, 04:57 PM
That's steep. I know it is very expensive. Thx
Old 08-06-2004, 11:29 AM
GMCTech GMCTech is offline
If the repair was done by a GM dealership, the parts and labor are covered under warranty, as long as you used GM parts and it hasn't been a year.
GM carries a 12 month/12,000 mile warranty on all standard GM parts, and the labor to replace.
Just a quick question- how often do you let your tank get below 1/4? The fuel pump is cooled by the fuel in the tank, and below 1/4 tank or so is also below the pump.
Hope this helps.
Old 08-06-2004, 03:29 PM
slacker_53's Avatar
slacker_53 slacker_53 is offline
How 'bout the fuel pressure regulator?? Just a thought, always start with the simple things first.
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 01-31-2005, 05:04 PM
davidhi davidhi is offline
Send a message via Yahoo to davidhi
Hope this helps.
.....actually, the fuel pump if replaced by GMC is covered for the life of the car. One of about 20 items which have a lifetime warranty. Why wouldnt GMC just warranty the part for life to start with??? I had the good fortune looking at a $750 repair bill. I called GMC corporate, complained and got a 50/50 split with dealer...was worth the call!!
Old 02-02-2005, 01:55 PM
84fiero123's Avatar
84fiero123 84fiero123 is offline
to be honest with you guys the pump is only $40.oo at napa for my 94 suburban and only takes about 2 hours on the outside to replace, even for a back yard mechanic you don't even need to jack the truck up. and gmtech is right dont run the tank below 1/4 to often or it wont mater if you replace it. good advise for any fuel injected car.
