Old 08-04-2004, 06:26 AM
chevy00 chevy00 is offline
squeak from front
i have a squeak coming from front of motor. could it be the idle pulley?have a 00 silverado 2wheel ext with 42000 milesa. any ideas
Old 08-04-2004, 06:32 AM
Re: squeak from front
or maybe its a chirp
Old 08-04-2004, 08:55 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Check your alternator..mine was doing this and needed the brushes and bearings replaced...I never did it though b/c it was charging fine, and a new one is like $200.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-04-2004, 09:01 AM
vnotaro vnotaro is offline
Saying you have a squeak at the front of the engine is kind of vague. You need to spend some serious time checking things out. I would start with the engine off and check the belt and pulleys. You may even want to loosen the belt and see if all the pulleys are secure. I could go on and on but the most probable culprit based on the limited info you gave would be the belt or one of the pulleys.
Old 08-04-2004, 11:16 AM
TXAGG05 TXAGG05 is offline
Every now and then I get a squeak from the front end which sounds like a belt squeaking, but it only does it every now and then when I'm turning left at just the right speed, and I could swear it depends on the weather.
Jeb
Old 08-04-2004, 12:57 PM
jeverett's Avatar
yeah..check the belt then, look to see if any visible cracks are showing..if so, replace it
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
