Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-03-2004, 11:58 PM
CRXSICO's Avatar
CRXSICO CRXSICO is offline
Send a message via AIM to CRXSICO
Exclamation Racing Harness??
I have a 88 honda crx si with Tezno racing seats. I want to by a 4 point harness, but i dont know where i can secure. I was told you just put it through the holes in the seat an the harness is secured by the seat its self, i'm not sure about that. I dont understand how the harness secures you in your seat if its secured by the seat. I dont have a roll cage nor do i plan on installing one. i know you can secure them to rollbar. Anybody have any suggestions or know of any products for my care that i can secure the harness two. I've gotten two suggestions so far, one was to secure the harness to a rear upper strut bar, the other was to purchase a rear lower support bar from Arospeed which installs in the floor of the car and secure the harness to that. Somebody help me please!!
"If it ain't a CRX Si, it ain't Shit!":greenchai
Old 08-04-2004, 11:37 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Racing Harness??
The harness (depending on brand) will come with clips at the end of each belt, with bolts on them. These bolts fit perfectly into two pre-threaded holes under my rear seat, but I have a 00 hatch. Check around and maybe you'll get lucky like I did.
Old 08-06-2004, 03:56 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
if you bolt it to the seat bolts its not actually held by the seat itself, but by the bolt mounting the seat. so as long as that bolt doesnt come out your harness should be kept in place to hold you in tight
Team Lonely Drivers
Old 08-08-2004, 01:30 AM
GWInquisitor14's Avatar
GWInquisitor14 GWInquisitor14 is offline
Send a message via AIM to GWInquisitor14
try a different forum, this is for technical engine shit
If the car really knew about all this trickery, hed be pretty mad.
FOR SALE
2 10" Alpine 1041 Type R
JBL BP 1200.1 1200 watt RMS amp
Message me if you are interested, make me an offer
Old 08-08-2004, 01:40 AM
Ricochet's Avatar
Banned
man, shut up.
Old 08-17-2004, 04:13 PM
djdxm djdxm is offline
Send a message via AIM to djdxm
Its not suggested to use a harness without a cage for safety factor. You are supose to mount the harness in the back on a cage, where it is about shoulder height. if you mount it on the floor or on the seat, it is below your shoulder. If you get in a wreck (hopefully doesnt happen anyway) but having the straps going below your shoulders, when your body is forced forward (collision) the straps will exert alot of stress and crush you down towards the floor (can cause injury). If you really want to use a harness safely, its recommended using a roll bar, or like the sparco harness bar.
http://www.sparcousa.com/harness_bars.asp
just a thought.
Jay
95 Civic Coupe, Future AF 10 Second Project Car
Sneak Preview of my Car.
"my closet needs a roll cage"
Need Webhosting? http://tiora.net :thumbup:
Old 08-17-2004, 05:33 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Re: Racing Harness??
Really? read again, it's for "in-depth motor heads..." meaning more technically advanced people or questions, NOT the head you put ON a motor.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 08-18-2004, 06:30 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Harness are a hot debate topic over on H-T. Someone don't care about the safety, some are religious about it. According to some the rear straps need to be no more or less than 10 degrees above or below the shoulders, even though Schroths are installed in BMW as a dealer option at the rear lapbelt positions. And others say that you shouldn't even use them without a roll cage period since your body will have no where to go if the roof caves in.
IMO leave the tree point OEM unit, it's plenty safe and designed for he car. If you want something to hold you in for spirited driving get some harness and run the rear anchors to the upper mounting point for the rear seat belts.
It has been my exeriance that a harness installed to manufacturers specs, is better in a real collision than OEM, and from what I have seen the roll cage harness bar are only situationally more safe, and if not wearing a helmet can cause more injury than they prevent.
Old 08-18-2004, 10:07 AM
Kven's Avatar
Kven Kven is offline
if you dont want to buy a cage try to fabricate a b-pillar bar and you should be able to strap it correctly.
