Old 08-03-2004, 11:27 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Vr4 Owners
at what mph does your 3rd gear top out at.
mine is 120-125. somewhere inbetween there.
just checking because i have got to at least 120mph in 3rd at least 5 times. but a cool guy in the street racing forum said that if my 3rd gear is at 125mph then technically my top speed is 215mph.
Old 08-03-2004, 11:28 PM
youngvr4's Avatar
STREET RACING GURU
Re: Vr4 Owners
especially those with 5 speeds
Old 08-04-2004, 02:55 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
5 speeds max around 125 in 3rd, 6 speeds max around 115 in 3rd. And yes, your top speed would be around 210-215 in 5th gear at redline. But have fun trying to get there. Your peak power is closer to 6k. The only way you are touching the "redline" in 5th is with lots of mods, and by then the "redline" will probably be higher(7.5-8k).
Old 08-04-2004, 05:33 AM
BB1970's Avatar
BB1970 BB1970 is offline
Re: Vr4 Owners
my 3rd gear tops out at around that sort of speed, i have read before somewhere that it is almost possible to top speed in 4th gear but havent tried that dunno if its true altho i have reached the 150mph mark in 5th and shut down although it was still pulling. this was off road of course on a track.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 08-04-2004, 02:31 PM
Hotshot8792 Hotshot8792 is offline
yes, and the 6-speeds gear out to about 235ish
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 08-04-2004, 02:35 PM
youngvr4's Avatar
STREET RACING GURU
Re: Vr4 Owners
HOTSHOT hows your project going man
Old 08-04-2004, 05:32 PM
sLADe781 sLADe781 is offline
Re: Vr4 Owners
235??? HOLY SH*T....won't the tires be torn to shreds at that speed? Man, that's some power...
Old 08-04-2004, 05:56 PM
youngvr4's Avatar
STREET RACING GURU
Re: Vr4 Owners
i bet the car in my sig can push it
Old 08-04-2004, 09:48 PM
Re: Re: Vr4 Owners
well, you have to understand, the car will never make it to 235 without some SERIOUS power, Matt Monet is the only person i know that has done it, and he calculated his speed by his tachometer. Stock, the car will probably only get to about 165, but at 165, you will only be doing, lets say, about 4800ish rpms or somewhere along the lines. Its not that the car can go that fast, its just what the gears are geared to go to.
Old 08-04-2004, 11:31 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Yea but theoretical top speeds are kinda cool to calculate, I remember spending a whole day in calc in high school doing just that and a few other auto related calculations with everyones cars, we had an awsome teacher.
Edit: ohhand does anyone know where the gears redline on a base/SL? I've never realy payed attention to the speed and I have only redlined mine like 3 times so far and only through the first 3 gears.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 08-05-2004, 12:09 AM
Re: Vr4 Owners
can't really say what they would be on a manual, all i know is that the FWD manuals are geared short compared to the VR-4s, 5th gear redline is probably at like 170
ATX is a different story, for me:
1st-2nd shift around 45
2nd-3rd shift around 83
3rd-4th shift around 135 (and that long gear can pull too)
4th, will top out around 200 at redline
