Old 08-03-2004, 10:27 PM
gentry gentry is offline
1980 trans. swap
i have a 1980 manual k10 p/u and i have a auto. trans. to go in it,and i was wondering if it would bolt up since the auto is out of a 2wd?
Old 08-03-2004, 10:35 PM
NWChevyGuy's Avatar
NWChevyGuy NWChevyGuy is offline
Re: 1980 trans. swap
It should bolt up fine. Make sure the rear tranny mount is the same. If you have a 4x4, and your auto transmission is for a 2 wheel drive, you will have to trim the output shaft with a grinder to match the same length as the 4 wheel drive. I think the output shaft on the 4x4 model is shorter so it can bolt up to a transfer case.
2001 Silverado
Crew Cab 2500 HD - 8.1 - Allison
6" RCD Lift with 35" BFG Mud Terrains
Airaid Intake - 4" Magnaflow Exhaust - Hypertech Programmer
