What's you power/weight ratio?
Power/weight ratio is using Ps(Hp)/kg?
Mine... 7gen, 4door, 2.0L, K20A3, EF1 about 1230/155=7.9 (all stock) How's yours? What ratio is good? |
Re: What's you power/weight ratio?
Hrm never figured mine out:
2450lbs/170hp (crank) = 14.4hp/lbs.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!Autocross Help Page Buy my Civic parts! |
That is the wrong equation. There is one out there, but I forget it. I mean think about it by throwing some extreme numbers in there. A 10,000lb car with 50hp will have 200hp per lb? Right.. Now working it backwards, SiRacer, your 14.4hp/lb is saying 14.4x2450 will equal 170.. do the math
more or less like 0.005 hp/lb
u divided wrong
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
weight / hp
mine is about 20 pounds per horse |
i think my 98 EX coupe is more than 22
Delony you said you had the K20 engine do you like it i am looking around for a possible swap in a year or two |
Ricochet your wrong man.
2550 lbs and 162 crank horsepower equals 15.7 lb/hp
Honda Civic 1999 EBP SiR Im not as fast as I am furious. 1/4 mile = 15.347 (sealevel) Porsche RS America BMW 323 01 Pictures of my ride (Pictures)
Re: Re: What's you power/weight ratio?
CivicSiRacer.... 2450(1111.32kg)/170=6.53..... |
pretty good... none modi, powerful than my altis toyota 1.6L |
couldnt tell you cuz I got no clue how much power a 11:1 B20 with LS cams, intake and exhaust pumps out. but the weights gotta be about 2250 with the engine and the wood in the back.
If i had to guess Id say its about 13.5lbs/HP my old ride though was around 2.5lbs/HP.
current -84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex history: -01 R1-04 daytona 600-94 teg RS-95 teg LS -91 teg RS-92 teg GSR-94 civic CX hatch (3 times) -94 civic DX-96 civic HX-97 Accord LX-72 superbeetle -74 beetle-84 silverado-66 c10-74 maverick-78 280z -84 200sx-86 tercel wagon-95 mustang V6 |
sure? |
Your equation is pounds per horsepower.. I'm looking for horsepower per pound, which would be a small decimal.
2400/315 whp (360ish crank) = 7.6lb/hp .. rough estimate holding 19psi with the new BC but mine kept dropping to 16-17psi on the dyno with a home made BC. Was going to use the GM boost solenoid with the EMS but it wasn't working and I took my AVC-R out before the dyno trip
This is on a built D series motor.
Assuming 15% drivetrain losses about 4.86 pounds/horsepower, or 2.20 kg/horsepower.
For me hp/kg would be 13.27 and kg/hp would be .075 and I drive a 2044lb (929.1kg) CX with 70hp; so the later seems more likely to me. |
