Inexpensive Paint Job
Recently I got an inexpensive paint job on my Crown Vic(Black). I assume the painter used a regular automotive enamel.Although the paint was applied satisfactorily without drips or sags, it looks a little "grainy" and the paint covering wasn't as shiny as I expected. What is done to "flatten-out" (?) the paint covering? Can I do it in the alley behind my house? Should I live with it or pony-up for an expensive paint-job? Will someone please help?
Signed: Mr. Growlgory |
Re: Inexpensive Paint Job
Enamel likes to fade unless you carnuba wax it often.
The grainy look is probobly orange peel which is common too showing the low spots in the paint job. All new cars have this type of paint job nowadays.
If its not clean CLEAN IT!! If its not gleaming SHINER UP!! If its not appealing BAG IT!!! |
you should beable to wet sand it to a nice shiny finsh, but im not positive on that, check with others, i do know that it takes alot of time and work but looks awesome when its done, (my friend recently did his 83 ford pickup and it looks like a brand new paintjob.
I wet sand to fix boo boo's and to remove high spots before reaplying the next coat/s lol the paint just goes on smooth when i prep the surface properly so I dont usually need to wet sand. Take your time , I also used a paint conditioner on fresh painted enamel say 30-60 minutes after the last coat and the paint cures and shows its full deepness as well. Wet sanding is very common and very usefull but not always necessary.
Re: Re: Inexpensive Paint Job
To Lucki17 and markgase2000: Thank you both for your advice.I did as you said but regretably not by myself. My Condo Association put the nix on car repairs and use of common Condo electricity! I tookk my CROWN VIC (named"COCKROACH") to a reputable body shop, and fer a buck and a half they wetsanded and buffed with "2000" compound.
The results were outstanding. The paint job is brighter and shinier than a factory clear coat. The only thing unnatural is tha fact that a ten year old car can look like new! I can actually see the reflections of rooftops on my hood! I'm happy and impressed Thanx Signed: Greg Pronobis from Chicago. |
glad i could be of help. enjoy your (new) car, im getting my car painted pretty soon too, a nice deep metallic blue.
Enamel is a very "gooey" paint if you will. It takes a lot of time for most enamels to dry so therefore when you paint multiple coats, or sometime even just one, the enamel builds up and really wants to run, which is your orange peel effect. If the painter would have slowed a little bit then a run would have occured. ALL enamel paint will do this with all painters. The difference in the quality of the paintjob(with enamel) is the quality of the wetsand that is done. once the painter is done with the colorcoat, the finish is sanded smooth with wetsand paper and a sanding block. Now the clear is added on top of that. This may sound odd. You may be saying, "But what about all those tiny scratches and dull finish of the paint, you can't just clear over an ugly paintjob". Actually even though the fine scratches(and I mean fine, very very high grit) are still in there and the finish is not shiny, the clearcoat will bring out an extreme brilliance in the paint. It will really wow you what that clear does. Now buff out your clearcoat, and voala you have a beautiful car! Hope this explains why wetsanding an enamel paint job can really pop the eye!
