Old 08-03-2004, 10:14 PM
Mustang_95_Coupe Mustang_95_Coupe is offline
can someone recommend some subs...
gonna have the box custom made by hailbanes friend, was wondering if anyone could recomend some 2 subs around 50-85(give or take a little) each thanks.
CURRENT AMP
Audiobahn A2200HCT 2 Channel High Current 1600W RMS Amp
High Current Circuitry
PVM MOSFET Power Supply
Double Sided Glass Epoxy Circuit Board
S/N Ratio: >100dB
Frequency Response: 10Hz-40,000Hz (+/- 1dB)
Remote Bass Control With Blue Backlight Knobs
Variable 24dB Hi-pass Crossover: 50Hz-750Hz
Variable 24dB Low-pass Crossover: 30Hz-120Hz
Variable Bass Boost: 0-18dB
Variable Bass Boost Frequency: 40Hz-100Hz
Variable Subsonic Filter: 20Hz-45Hz
RCA Throughput Connections
4-way Protection Circuitry: Thermal, Short Circuit, Overload, and DC Offset
Dual Cooling Fans
VU Meters Indicating Output Response
Cobalt Blue Illumination
High Gloss Chrome Plated Finish
Dimensions: 3 11/16"H x 12"W x 23 1/16"D
4 Ohm Stereo: 200 X 2 Watts
2 Ohm Stereo: 400 X 2 Watts
1 Ohm Stereo: 600 X 2 Watts
4 Ohm Mono: 400 X 1 Watts
2 Ohm Mono: 800 X 1 Watts
1 Ohm Mono: 1600 X 1 Watts
Old 08-04-2004, 02:12 AM
Abell255's Avatar
Abell255 Abell255 is offline
Send a message via AIM to Abell255
12"? How much power do you want to put to each sub?
Old 08-04-2004, 02:52 AM
Re: can someone recommend some subs...
not sure, just as much bang for the buck pretty much.
Old 08-04-2004, 09:10 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
RE xxx, Adire Brahma, magnum d12, e12av2
www.cloudcity.deviantart.com
Old 08-04-2004, 10:35 AM
loismustdie loismustdie is offline
well since you said 50-85, i'd say some phoenix gold ti's, those will be the best bang for your buck
the aquabats are seriously the best band in the world
Old 08-04-2004, 03:16 PM
anyone have any links to ebay?
Old 08-04-2004, 10:44 PM
Haibane's Avatar
doh, missed the 50-80 part...
Old 08-05-2004, 03:22 AM
anyone im gonna email the guy for the box soon and would like to let him know what subs i have.
Old 08-05-2004, 03:31 AM
also i have around 250 total to spend on box/subs together so if anyone has any ideas lmk
Old 08-05-2004, 07:49 PM
save up some more money, or spend it all one one sub instead of 2....
Old 08-05-2004, 07:51 PM
i was thinking of getting to kickers square.
Old 08-05-2004, 07:55 PM
Re: Re: can someone recommend some subs...
do you mean 2 square kickers? and those don't have the best sq, but will do fine, aren't they out of your price range?
Old 08-05-2004, 10:09 PM
ya might spend a lil more can get 2 solar barics for like 250 on ebay.
Old 08-06-2004, 12:17 AM
Haibane's Avatar
The only good kicker IMO is the cvr
Old 08-06-2004, 12:18 AM
hmm ic, btw i emailed your friend last nite but no response.
