Old 08-03-2004, 08:55 PM
Palozzi Palozzi is offline
Angry Harness Swap
Thanks to you all for responding. I know someone out there can help me. I have an engine stamped D16Z6 it is a SOHC. I believe the block is identical to D16A6 only the head is different. I need to know what to buy to make this engine work using the ECU from the stock 89 Si.I know there are several "piggyback" harnesses available. For instance I notice the "MAP sensor on the Z6 is located on the throttle. In the 89 D16 I don't know where the map sensor is is it not visible to me.I 've also heard the distributor and o2 sensor are additional wires needed. If you know the tech stuff or can point me to someone I would again appreciate it.
David
Old 08-03-2004, 09:23 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Re: Harness Swap
http://www.pgmfi.org/twiki/bin/view/...KurtsOBD0-OBD1
theres your link on the wiring
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
