Old 08-03-2004, 06:08 PM
jurrasic519 jurrasic519 is offline
Send a message via AIM to jurrasic519
Im Begging Everyone Please Help With My Problem No One Ever Replies To My Post
i have a 99 gsr. I was racing and a spring shot out in my clutch and wrecked my clutch...got it replaced. My car was running terrible though. It makes a put put put put put noise really quickly and shakes bad. I thought it might need a tune up so i changed the plugs and wires. That did nothing so i ran a compression test and cylinder 1 had no compression. Im thinkin its one of two things a ring (which i hope) and a valve (i really hope not). Its not smoking so i kinda dont think its a valve but ive seen weirder things. I know i should take off the head but if someone could tell me to check some things first i would rather do that cuz i have to buy new head studs from just taking off the head. Now also the car shuts off after awhile of running cuz the rpm's are low from no compression. Please someone if you know what to do or have had the same problem help me out i havent had my car for 4 months. THANKS
Old 08-03-2004, 06:18 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: Im Begging Everyone Please Help With My Problem No One Ever Replies To My Post
do a leakdown test. that should pinpoint you to where you are lossing your compresion. if you hear the air coming out th intake, you got a bad intake valve, if ait comes out the exhaust, bad exhaust valve. if it leaks and you can;t really hear it, good chance you gat ring problems. It seems awfully odd that you have absolutely 0 compression, are you sure you did the test correctly?
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 08-03-2004, 06:42 PM
well the first time it came up with like 20 the second time it came up 0
Old 08-04-2004, 05:49 PM
b16a3sol b16a3sol is offline
what did the other cylinders look like?
a leakdown test is your best bet before tearing apart your motor. definitely start there.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 08-05-2004, 08:08 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
i would suggest the same thing, a leakdown test is the quickest way to determine the problem, but id also try another compression test, if you got such low numbers, thats like all the rings have melted in there, and there is nothing stoping the flow of the air.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-05-2004, 10:18 AM
thanks for your help i will try that test today. i tried the compression test again and it still came up 0 in cylinder one. Im thinkin i have to get a new set of rings. Im takin the head off today or tomarrow so i will find out the problem then. My friend was tellin me that if it is rings i probably scored my cylinder which has to be honed but if it gets honed all the cylinders have to be honed. If you have bigger cylinders you need bigger pistons and this is giving me a big headache and its costing way to much money for such a small thing. Does a company make rings that are a little larger so i dont have to get new pistons or does the guy who told me not know what hes talkin about? Also my friend said he needed a ridge reemer what the hell is that?
