Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 08-03-2004, 05:03 PM
88zccivic 88zccivic is offline
this is a hard one for you guys
ok i have a dohc zc with a t25 turbo and an apexi safc2 with 450cc injectors and an msd 6a box. heres the problem all of this was in an 88 dx civic and i crashed it so i switched everything over to a 90 civic std
no the car sounds like it has a dead cylinder and is smoking bad
also the crankcase filled with gas. i have already put new injectors and spark plugs in and still the same thing any ideas?
Old 08-03-2004, 11:22 PM
WhiteLine Civic WhiteLine Civic is offline
you broke it
first thing is what color is the smoke if its white you prob blew the head gasket, second thing you prob locked up a piston thats what I did in my the first time I blew my motor, third is you could have spun a bearing. pull the oil pan check the bottom end, also pull the head. it has to be one of the 3 hope this helps dude.
Old 08-04-2004, 10:18 AM
Re: this is a hard one for you guys
the smoke is white but when i tryed to drive it
the power would kick in and out at certain rpms
any of those problems would make it stay week the whole time right?
Old 08-04-2004, 11:32 PM
what kind of fuel system do you have, and are you running lean? I still think you toasted the motor dude. just dop the oil pan and see if there are any shavings in the pan, that won't take to long but then you'll know if its the bottom end or not.
Old 08-05-2004, 04:40 PM
i just did a compression test and i got 180psi on all four cylinders i have a walbro 255 pump, 450cc injectors and a safc2
Old 08-06-2004, 01:20 AM
thats great, what kind of fuel system do you have, and are you running lean? I still think you toasted the motor dude. just dop the oil pan and see if there are any shavings in the oil pan. did you do any tech work or not... I.E. pull head, drop oil pan. if not then dude do one of the two listed.
Old 08-08-2004, 03:27 PM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
hey what does that white smoke smell like to you? do you think its an oil burning smell or coolant?
Old 08-09-2004, 10:01 AM
the smoke smells like fuel
Old 08-09-2004, 10:23 PM
all a fuel smell means is your running rich.
Old 08-09-2004, 11:53 PM
Rating's Avatar
Rating Rating is offline
Send a message via AIM to Rating
I have a Walbro pump, it did that to me for a while.
it cleaned up after i gave it an oil change, the reason it happened to me was the oil change before I accidently put... oh i donno two Qts Over. Wink Wink. I didnt realize it at first because i was being cocky about my new turbo, and just wanted to drive the hell out of it... as for the gas smell with a walbro more than likely everytime you fill your tank up, its gonna stink like gas all the time sorry bro. But do check your oil get it changed. Also check your exhaust pipping for any wet substance on it, my shit was wet as hell when I overfilled my oil. If that doesnt work for you take your oil pan off and check for shavings.
Im not proud of my car because its fast, Im proud of it be cause I built it that way.
Old 08-10-2004, 01:37 AM
i asked baout the smell because because i think a white smoke with a different yet off smell (i dont know how to describe it) would mean your head gasket is gone. It's better to erun rich than lean.
you said : "this was in an 88 dx civic and i crashed it so i switched everything over to a 90 civic std."
did you play with you timing belt when you pulled the sawp?
hmmm... did you check your timing recently?
