Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-03-2004, 04:59 PM
88zccivic 88zccivic is offline
this is a hard one for you guys
ok i have a dohc zc with a t25 turbo and an apexi safc2 with 450cc injectors and an msd 6a box. heres the problem all of this was in an 88 dx civic and i crashed it so i switched everything over to a 90 civic std
no the car sounds like it has a dead cylinder and is smoking bad
also the crankcase filled with gas. i have already put new injectors and spark plugs in and still the same thing any ideas?
Old 08-03-2004, 05:19 PM
b16a3sol b16a3sol is offline
Re: this is a hard one for you guys
what kind of smoke is it? what condition is the new engine in? hows the compression on the new motor?
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 08-03-2004, 11:12 PM
white smoke some black when i rev
i engine has 40k miles on it
i havent had a compression test on it but it was fine when it was in the other car
Old 08-04-2004, 05:47 PM
white smoke usually means the head gasket is blown, as coolant is leaking into the cylinder. how is your coolant level looking? my guess as to why it seems like there is a dead cylinder, is because there is one. the gasket probably crapped out on you at that cylinder, and you have lost a lot of compression from it. do a leakdown test if possible, but a compression test would help also.
Old 08-05-2004, 04:44 PM
i did a compression test and i got 180psi on all four cylinders the coolent has also been fine
Old 08-06-2004, 04:14 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
run the car and pull off every spark plug wire one at a time and see if the idle changes at all
Team Lonely Drivers
Old 08-09-2004, 09:23 AM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
i say a bad oil pump causing
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 08-09-2004, 10:04 AM
with the car running i pulled off each plug wire one buy one and none of them changed it at all
but if i unplug two injectors at the same time it will run better for a few seconds
Old 08-10-2004, 01:13 AM
probably running rich, check your safc
Team Lonely Drivers
