Old 08-03-2004, 02:34 PM
TwentyPints TwentyPints is offline
Exclamation Will these tires fit?
i have a 04 reg cab short box. i was interested in puttin on BF Goodrich all terrains. i wanted to know if anyone has these tires how do they perform, etc. and will a 285/75R/16 fit without any modification or rubbing? i have 255's right now. two tire places told me 285's were prob too big and wouldn't fit. does anyone else run this size? any pics appreciated!
Old 08-03-2004, 04:29 PM
Bz02z71 Bz02z71 is offline
Send a message via MSN to Bz02z71 Send a message via Yahoo to Bz02z71
ya
ya they will fit as far as i know, i have an 02 z71 and mine fit fine.
Old 08-03-2004, 05:35 PM
Thunderbolt Thunderbolt is offline
Two wheel drive or four wheel drive ?? If it is four wheel they should fit, But if it is two wheel drive then no way.
Old 08-03-2004, 07:19 PM
Re: Will these tires fit?
its a 2wd, silverado base model.
whats the largest size i could do then?
Old 08-03-2004, 11:13 PM
if they dont fit sorry for the bad info, i am going off what worked for mine, again sorry
Old 08-04-2004, 08:57 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
285's on a 2wd might scrub inthe front...the back will be fine. If you can find a way to lift the front end a bit, then maybe they will fit, or eithr you can trim your air dam so they wont scrub... I think 265's look good on a 2wd. My signature pic is 285 Cooper A/T's they fit without any lift..
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-04-2004, 08:10 PM
what about a 275/70R/16? do you think those would fit?
what is the difference between a 70R and a 75R anyways?
i have a 255 on there now, and i want something noticable wider, i like that look. not sure if the 265's would be that much more noticable?
Old 08-04-2004, 08:59 PM
Old 08-05-2004, 07:08 AM
jeverett's Avatar
Lets take a 265/75R16 for example...
THe 75, a two-digit number indicates the tire's aspect ratio. It compares the tire's inflated section height, which is the distance from the bead to the tread, to its section width (maximum). An aspect ratio of 75 means that the tire's section height is 75% of the tire's section width. For clarity, the section width in millimeters is separated from the aspect ratio by a slash (/).
In other words, its how tall the tire is...the 265 is the width.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-05-2004, 11:45 AM
so which would look bigger the 265/75
or 275/70?
Old 08-05-2004, 11:59 AM
jeverett's Avatar
the 275/70 would look wider...my truck has factory 265.75.16 now and they look good..im trying to get a recent pic to add, but cant get it to download off my palm pilot...
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-05-2004, 04:48 PM
i was thinkin of BFG's all terrain, can you recommend any others?
Old 08-06-2004, 07:26 AM
jeverett's Avatar
Those are an excellent choice, as well as Bridgestone Dueler A/T Revo's, the Cooper A/T's like I have are also good. I also like the Yokohama Geloander series tire.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-06-2004, 06:35 PM
thanks for the help. i was surprised the 275/70R were alot more $ than the 265/75R.
the 275's are like $230 a peice (CDN $$). and they 265's $190. i wonder how much a difference they would make to the 255's? thats alot of coin to only go up a size or two i thought.
