Old 08-03-2004, 01:12 PM
bobmga62 bobmga62 is offline
Only one speaker left
Hi guys, asked this before with no response... hopefully a new posting will generate response
On my 96 blazer, my rear speakers failed to work years ago.. now, my right hand speaker only works intermentedly (sp?)... more off than on..
I'm down to one mono speaker...just like my 64 VW AM radio from many decades ago..
has anyone experienced the same, and know of the solution..
thanks
B
Old 08-03-2004, 01:25 PM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
Re: Only one speaker left
Take the speakers out and check your connections. If you listen to music loud then it may rattle the connections loose. if not then i dunno.
Old 08-04-2004, 03:51 AM
lowS-DIME lowS-DIME is offline
u may have blown them... burned the voice coils to the point of non function... a solution... replace them.
plans for my new car....
Old 08-06-2004, 12:42 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
We can't really help you on that bro.
Go look at the speakers for yourself.
Old 08-08-2004, 03:17 PM
Omar1127 Omar1127 is offline
My speakers were bad to.
All of my speakers have gone bad 1 by 1. Had to buy replacements and install myself. Not to hard.
Old 08-29-2004, 06:04 PM
bilgriff bilgriff is offline
I have a bad rear speaker on my 99. How do the door panels come off?
Old 08-29-2004, 10:03 PM
BlazerLT's Avatar
AF -Advisor
yes
Old 08-30-2004, 10:34 AM
To remove the rear door panels. unscrew the door handle cover. then pry up the little plastic plate inside the armrest. unscrew the bolt in there. then pry open the door panel. you have to pull it because there are about 5 to 10 little pressure hooks but they just pop on and off. Good luck.
Old 08-30-2004, 01:20 PM
BlazerLT's Avatar
AF -Advisor
And have some extras handy.
The snaps will sometimes break.
Old 09-05-2004, 05:09 PM
Trail Blazin 96 Trail Blazin 96 is offline
if replacement doesn't work the next best thing is to gut the factory wires and run your own best to go with the smallest number you can, not the smallest wire!
