Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-03-2004, 11:58 AM
shyguy98ex shyguy98ex is offline
Send a message via AIM to shyguy98ex
would this be a good set-up?
i was thinking about buying a JDM b16b and...
putting on a greddy turbo kit, aem fuel rail, new spark plugs... dunno what kind, AEM high flow fuel filter, AEM fuel regulator, skunk2 cam shafts, AEM cam gears, greddy intercooler, APEX'i turbo controller, a ground wire kit, some kind of clutch, new pistons and sleeves, an AEM EMS... not for me to screw with..., AEM pullies, new axels, new cam shafts....
what else should i get... and will this work well?
i'll set the boost at 2psi for daily driving and 12psi for racing people.
Old 08-03-2004, 05:24 PM
b16a3sol b16a3sol is offline
Re: would this be a good set-up?
you can save money if you just buy a US b16a. you are replacing pretty much everything that makes it a b16b anyways. sounds like a good start to a fast car. also, you could easily set the boost to about 7-8psi for daily driving, especially since 2psi would do just about nothing. good luck with it.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 08-06-2004, 02:37 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i agree with b16a3sol, if your going to be replacing everything that makes it a type r then its not worth it
Team Lonely Drivers
Old 08-07-2004, 02:47 AM
JDMrexBoi's Avatar
JDMrexBoi JDMrexBoi is offline
Banned
duhhh!
