Go Back   Automotive Forums Car Chat > Peugeot > 406
Old 08-03-2004, 09:21 AM
frazreid frazreid is offline
Send a message via MSN to frazreid Send a message via Yahoo to frazreid
406 Handbrake Problem
Hey all !
Got a 406 LX with an intermittant Handbrake problem (Electrics)
sometimes when then handbrake is applied when the car is stationary , I get the warning "Brake Fluid Level Low!" with the beeper
and of course the fluid was only changes 2000 miles ago on a major service , where the brakes were checked too !
so I bought myself the Haynes manual for my car and found that there are 2 switches (one for handbrake and the other for Brake fluid level) that are completely separate from each other and only connect together into a larger connector but I cannot find where this (possibly controller) is in the car.
Peugeot have themselves not been able to find the cause of this .
they say there is no problem with the handbrake !
Can someone please help !
Old 02-14-2005, 03:34 AM
Duncan2005 Duncan2005 is offline
Re: 406 Handbrake Problem
Hi, did you manage to find out what the problem was with the "brake fluid level low" warning light. I have a Peugeot 406 and am having the identical problem. It seems to be weather dependent i.e. it seems to be less of a problem in the colder months. Any information you have would be greatly received. Kind Regards
Old 02-14-2005, 10:34 PM
Mr Vegas Mr Vegas is offline
Yeah the handbrake switch is faulty,this throws up the "brake level light low" light on the display.
It's a small L shaped black switch behind the rear ashtray/compartment,you'll need to lift up the compartment enough to get your hands under to replace the switch.
This is a common fault with these switches,so a peugeot dealer should have the part.
There ya go....good luck!
p.s-you did check the brake fluid level right?
