| Off-Topic Talk about anything other than cars. |
more problems!
so im driving home from work yesterday and i go to shift into 2nd and my car dies out of no where! luckly i cost into an empty parking lot.. it just cranks and cranks.. sometimes it will start but only for a split second then dies? i checked my fuel rail.. there is a little like valve stem and when i push the button in fuel comes out so that means its not the pump correct? not sure but i don't no how else to test it.. also i checked my plugs and they arn't wet so i don' know if im gettin any fuel to them.. i took a plug out and set it on metal but i didn't see spark? i don't have any idea what could be wrong.. it just had the motor and computer replaced 2 weeks ago! if anyone has ne ideas please let me know.. thanks
Re: more problems!
Plugs and/or wires could be the issue. Inspecting the wires should do the job, but plugs may need to be replaced. Do you smell gas when you try to start it?
1996 Eagle Talon |
Re: more problems!
the fuel filter could be clogged to ,it allways helps to replace it ,there cheap
![]() 1998 Eagle Talon TSi AWD 6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband |
Re: more problems!
did you try to reset the ECU?
Re: more problems!
Yes..Try Reseting the ECU. I had a similar problem before. I had to replace mine but If you just did, it might just need a reset.
yea i reset the ecu.. no im not smelling gas.. the plugs are new.. only got like 100 miles on them... sometimes when i try to start it.. it will start and idle for a few seconds but when i hit the gas it dies instantly! could it be my sending unit? im gonna try and figure out how to test it.. anymore ideas would be great! thanks again
Re: more problems!
Did you gap your plugs correctly?
Re: more problems!
lol yes
