Old 08-03-2004, 01:58 AM
Mustang83 Mustang83 is offline
Cat Converter
Will a cat with broken insides cause sluggishness in the cars performance? Is there a way to fix them rather than purchase a new one? (Which I'm sure is againsed the law) But is there?
Old 08-03-2004, 02:41 AM
Mustangmann Mustangmann is offline
Send a message via AIM to Mustangmann
ya it can kill performance, but i don't know how to fix it without getting a new one. get one from a junk yard
Old 08-03-2004, 10:36 AM
stangfreak7 stangfreak7 is offline
Send a message via AIM to stangfreak7
Well you can do one of two things that i know of. First you can buy a new one, or you can take it off cut it open and gut the whole thing and weld it back together. But if you get caught doing this it is a 10,000 dollar fine on the spot, or atleast where im from it is. Either way you should look into the problem, cats that are getting stoped up will start causing major problems it not fixed in time. I had a 95' grand cherokee that had the same problem and i ended up just gutting the cat on it.
Old 08-03-2004, 10:44 AM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Cat Converter
i dont think you can get cats from junkyards anywhere in US i know its not allowed in my state and nearby ones.
I say get catco cats youll pass smog free up some flow and be cheaper then OEM
Old 08-03-2004, 11:44 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: Cat Converter
You dont have to cut the converter open to gut it. Ever heard of a tire iron? Just knock the guts out of it and weld it back up. '95 and older cars that came from the factory with cats just have a visual inspection for them. If you have atleast a housing then you pass that part of the inspection. Atleast thats how it is around here.
Old 08-04-2004, 02:16 AM
Well I guess maybe I'll try the tire Iron method first and see If I can knock the guts out that way before I open it up. I just had the car pass "Air care" (Thats what they call it up here in Canada) So I wont have to worry about it till next July. New cats are about 350$ up here.
Also, how important is the heat shield? It's making an annoying rattle. Is it cool to take it off?
Old 08-04-2004, 03:08 AM
Wolf's Avatar
Wolf Wolf is offline
Send a message via AIM to Wolf
Re: Cat Converter
http://store.summitracing.com
Catco universal replacement high-flow cat = about $50. Perfectly legal to replace it.
Old 08-04-2004, 09:19 AM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
I believe that Magnaflow has a Cat if your really looking for flow...
Old 08-05-2004, 09:33 PM
351wStang's Avatar
Re: Cat Converter
How close is it to the floor board? What about gas lines? If its auto what about tranny lines. Alot of heat builds up in converters. I got a 3rd degree burn from one the other day. You can fix the heat sheild where it wont rattle if you want. Noisey heat sheilds are pretty common. A peice of thin metal strap exhaust hanger with the holes in it works pretty well, just run a small bolt thrue the holes to clamp it shut around the converter and heal sheild. Quick, easy, cheap fix that works, for a while atleast.
Old 08-05-2004, 10:06 PM
boosted331 boosted331 is offline
When I was still a young'un my Dad bought a new ranger in 92, heat shield fell of the cat in 2000 when I was moving out. Still drives it every day to work, cept now it has an S-trim on it, and he hasn't blown up so far.
