Old 08-02-2004, 10:05 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
the engine revs itself ... maby its proud?
came home from a buddys house today and noticed when i stop the engine revs itself up every 5-10 seconds or so when its ideling at a redlight or something like that. Drives fine and it revs to maby 1500 or less (hard to tell, no tach) so you cant tell at all unless you turn the radio off. Its not throwing any codes and it doesnt do it when its in gear. anyone had this issue?
Old 08-02-2004, 10:26 PM
MunG35's Avatar
MunG35 MunG35 is offline
Send a message via AIM to MunG35 Send a message via Yahoo to MunG35
Re: the engine revs itself ... maby its proud?
yeah i get it in my auto civic when i'm parked, it has to do with the a/c, when the a/c kicks up a notch so does the car revving, or at least that's what my car does. check it out for your car.
Are stock tips worth anything? See how the experts do: http://www.stocktiptrader.com
Old 08-02-2004, 11:52 PM
Forunn Daberator
no ac so thats not it.
Old 08-03-2004, 12:26 AM
jgoertz7 jgoertz7 is offline
this might sound crazy but was your blinker on? my rex did a little revving of it's own when my blinker was on. My battery had been jumped too many times, and it hardly had enough power to run even the smallest electrical. so I had electrical pulses going through the car effecting the fuel system.
Old 08-03-2004, 12:33 AM
Forunn Daberator
nope, even turned the sterio off and it did it. Didnt mention it up there, but it does it repeatedly, not just once.
Old 08-03-2004, 02:10 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Vac leak can cause this problem. take some water in ia spary bottle and squirt it on all the Vac hoses it the motor dies you found the leak.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 08-03-2004, 06:20 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
im with Cjz89civic on this one if not it coudl be your mixture as my daihatsu would "hunt" if the mixture and idle werent setup correctly
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 08-03-2004, 01:24 PM
Hybrid1990crx's Avatar
my civic does this once and a while. I've tried to fix it many times but never have been sucessful. Check vac lines. Also check your throttle cable if it is adjusted right.
