Old 08-02-2004, 06:07 PM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Help creating welds
Hi Guys
Whilst working on the 1:12 Skyline I want to add some weld detail to things like the exhausts, IC, and other parts.
Can I hear you ideas for creating realistic looking welds.
My only idea is putty and carve them in but other ideas are welcome
Thanks in advance
Steve a.k.a. Hiroboy
Old 08-02-2004, 06:16 PM
ramunozs's Avatar
ramunozs ramunozs is offline
With a small brush lay down a line of silver paint wher you want the weld line, wait until the silver paint is almost dry and make the weld marks with the tip of a small screwdriver, then let the siver paint to dry completely.
Old 08-02-2004, 06:19 PM
blueboost's Avatar
blueboost blueboost is offline
Re: Help creating welds
try a different color paint and dab them on.
for instance if you are painting the intercooler w/ aluminum try using some steel on the tip of a fine paintbrush and do one of those "dab and push and dab and push" (hard to explain). Use a thick paint, nothing too thin.
The color choices were only for example, getting the coloring right will be up to you. Hope that helps a bit, if only to give you a different method to experiment with.
let us know what you come up with!
Old 08-02-2004, 06:34 PM
ramunozs's Avatar
Here's a tutorial:
http://www.finescale.com/fsm/objects...cweldseams.pdf
Old 08-02-2004, 08:15 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
There are a couple methods I know of. The first is in FOTW's intercooler how to, and it works quite well. The thin line of putty, laid over the seam, then textured with a soft paintbrush. It may, however, be better to use a knife blade to "carve" the texture in the soft putty on such a large scale. You could even make a tool by filing PE fret, at that scale.
The other way I know, but haven't been able to get to work right uses plaine white glue. Tak the bottle of glue, and run a bead of it along the seam. Do it like you would ice a decorateive trim on a cake, squeeze some out, and push it back, move the bottle forward, squeeze some out, push it back.... make any sense? The reason I could never do it was because it was hard to get the tiny amount of glue needed for 1:24. It might work for 1:12, though. Be mindful, white glue shrinks as it dries, it may take some experimentation, but the good part is if it doesn't work, it comes off easily.
Old 08-02-2004, 08:25 PM
SonyMobile's Avatar
SonyMobile SonyMobile is offline
Send a message via AIM to SonyMobile Send a message via Yahoo to SonyMobile
Fly On The Wall had a neat way of doing it using a bit of rolled putty and a paintbrush, If you check the Tutorial section he shows it under the Intercooler Tut.
Old 08-02-2004, 08:28 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
you can just use some chrome silver paint, and paint a thick line to simulate a weld , i use that for exhaust headers and it works great,
also you could use white glue and apply it with a toothpick, then paint it after
another way is to put a light coatof liquid cement, and then stabb it repeatedly with broken tip X-Acto blade
Old 08-02-2004, 09:04 PM
Veyron's Avatar
Veyron Veyron is offline
The putty method sounds great if you need texture, and in modeling that type of texture equals detail, especially on a 1/12 scale.
I used 5 minute epoxy on my Ducati by mixing the A and B components and waiting til it got tacky then I stuck a toothpick in it, pulled it out so that the epoxy was 'stringy' and wrapped it around the exhaust.
Then you can paint it however you want.
Old 08-02-2004, 09:19 PM
scaleracecars scaleracecars is offline
Originally Posted by Hiroboy
Hi Guys
Thanks in advance
I use very thin styrene rod. Cut or scrape a small line in or around the part then glue a very small styrene rod into the groove. Glue the rod in place using a liquid glue such at MEK or tamiya very thin cement. After it dries coat it heavily with more cement and use a tothpick or old brush to make the dimples you see in welding. Here is a link to a 1/24 scale muffler from a Hasegawa Lancia 037 I built a few years ago.
http://www.scaleracecars.com/webimages/lancia%20muffler
Best Regards,
David
Old 08-02-2004, 10:42 PM
bigford550's Avatar
bigford550 bigford550 is offline
scaleracecars weld is the best looking weld
i have ever seen!! 1/24 or in 1/1
i'll try his method real soon
Old 08-03-2004, 12:55 AM
Hiroboy's Avatar
Thanks guys you have given me some great ideas, which i'll try out tonight.
Chears
