Old 08-02-2004, 07:49 AM
crupian crupian is offline
Angry Keyless Entry Keypad on door but no code
I recently purchased a used 1995 Windstar with the keyless entry keypad on the drivers door but I don't have the code to enter, can anyone help me create my own code or obtain the code.
Old 08-03-2004, 08:58 PM
busboy4 busboy4 is offline
Hi
try this: remove the U shaped trim panel at the bottom of the dashboard area near the floor. Behind the lower storage door area there is a vertical dash frame member. Attached on the back (engine side) of the member should be the "brains" of the keyless entry. Look for a square shaped electronic box about 3-4" square. It should have an antenna lead plugged into it that looks like the one on a car stereo. Hopefully attached to this box - you will likely have to remove it/or use a mirror - is a sticker with the default code. Use that code, or use it to enter your own - your owners manual should tell you how.
In the meanwhile, did you know you can lock the car from outside using the last two pads together?
Good luck
Old 08-04-2004, 11:40 PM
Re: Keyless Entry Keypad on door but no code
Thank You, that worked out for me and now I have my code, the only thing I need now is an owners manual.
Old 08-05-2004, 08:06 AM
Hi
glad you found it. Now to use it: enter the default code on the door and the drivers door should unlock. Press the 3/4 button within 5 seconds and the slider/liftgate should unlock. Press 7/8 and 9/0 together and the doors should lock.
To change the code (actually you are adding a code. The default code will always work in addition to your added code) enter the default code, press 1/2 within five seconds then enter your new five digit code. You use it the same way as the default.
Good luck. Wish I had the keypad. Original owner got everythng but.
