Old 08-01-2004, 10:26 PM
matt11583 matt11583 is offline
r/t 1/4 mile times
does anyone know what a stealth r/t runs in the 1/4 mile with stock parts????
Old 08-02-2004, 12:14 AM
StealthModifier StealthModifier is offline
Re: r/t 1/4 mile times
i believe its around a 15.4
Old 08-02-2004, 10:07 AM
whats its 0-60 time like???
Old 08-02-2004, 10:17 AM
Raz_Kaz Raz_Kaz is offline
0-60 is 8.5 secs
and 1/4 mile is around 16.4
Old 08-02-2004, 10:53 AM
5 Point 7's Avatar
5 Point 7 5 Point 7 is offline
Re: Re: r/t 1/4 mile times
Originally Posted by Raz_Kaz
0-60 is 8.5 secs
Doesn't sound right. My Probe GT I had ran high 15's, low 16's. Best as being a 15.7 And they have 62 more hp, I'd thought they would have been quicker than that.
Old 08-02-2004, 10:59 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
The R/T is a low to mid 15 second car. Its the 222 hp version of the stealth. The ES version will be the one in the 16s.
Resistance Is Futile (If < 1ohm)
Old 08-02-2004, 11:07 AM
The 3000gt SL is the same as the Stealth R/T no?
http://www.ssmoparmuscle.com/speedcomp.htm
Old 08-02-2004, 01:38 PM
YogsVR4's Avatar
Depends on the year.
Aside from that, the numbers from that site for the 3000 (and I'm sure many other cars) are wrong by quite a bit. I don't know what they used to justify them, but it looks as though someone just made them up on the fly.
Old 08-03-2004, 12:07 AM
How can a R/T run low to mid 15's and an ES runs 16's and they both have the same engine??
Old 08-12-2004, 09:59 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Thing is they don't have the same engine, the ES has only 12 valves and is a SOHC, like the 97+ base 3000GT.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 08-12-2004, 10:22 PM
My ES has a DOHC and 24 vavles.. The ES has the exact same engine as the R/T
Old 08-12-2004, 11:18 PM
Thourun's Avatar
Ok well if not the ES there is one grade of stealth that only has a SOHC. Sory thought the ES was the base trim, wow there were alot of trim levels lol.
1995 3000GT VR-4
Old 08-12-2004, 11:23 PM
lol, theres a base with the SOHC.. then theres the ES and R/T with the DOHC.. and of course the R/T TT
Old 08-23-2004, 10:27 PM
91stealth 91stealth is offline
what does the rt/tt do in the 1/4 and 0-60?
Old 08-24-2004, 02:09 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
13.5-14.2 and 4.8-5.5
