Old 08-01-2004, 10:20 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
condensation
dose anyone know the best way to clean out the condensation in the head lights and keep it out?
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 08-01-2004, 10:30 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Re: condensation
yea what i did is get a real thin oil tube and place a blow dryer pointing inside the tube and toward the inside housing. Take off the light (s) of course. This may take you one or two times to do, but it definately works my friend. Trust me had the same problem and damn is it fucking annoying. Also check if the gasket or washer (whatever it is) is still there, if its not get one because that is probably why you have this problem.....as i did.
Old 08-02-2004, 12:25 AM
george536's Avatar
george536 george536 is offline
Re: condensation
for me for some reason i need to have the gasket thing off or else water gets in there. its weird. if i have it closed up it gets all watery inside.
