Old 08-01-2004, 07:31 PM
FireBallKY FireBallKY is offline
Send a message via AIM to FireBallKY Send a message via Yahoo to FireBallKY
Question Non factory spec'd rims..
I have a '96 Nissan XE ext cab. Factory rims are 14" and I have a set of 15" rims with 205/50's. What has to be done, if anything, to adjust the odometer/speedometer to work accurately?
Old 08-01-2004, 09:20 PM
01rollaS&accordv6 01rollaS&accordv6 is offline
Re: Non factory spec'd rims..
have the gear drive system calibrated and reset to your new wheels and tires take it to a shop they shouldn't charge much about 15 to 20 dollars.it is usually located next to the transmission
Old 08-02-2004, 02:00 PM
Thanks a bunch. I'll check into it today. When I had them on before, my speedometer and odometer were waaaaay off.
I have asked a few people in the past, including a couple of shops, and they said I could run the rim but would have to adjust the tire to make everything normal. As you can see, I wasn't totally satisified with that answer.
Thanks again.
Old 08-03-2004, 01:03 PM
SaabJohan SaabJohan is offline
Re: Re: Non factory spec'd rims..
Thanks again.
Tire size should be adjusted so the wheel size stays the same, anyone who has said that is correct. In many cases it's illegal to change wheel size.
Old 08-03-2004, 02:38 PM
Illegal? People change tire/wheel sizes ALLLL the time. Makes me feel like we're in a communist world. hehe Would that be for potential, future selling purposes?
Old 08-05-2004, 06:12 AM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
What he means is the overall diameter of the tire and wheel. For example, when you plus size the wheels you buy lower profile tires so the overall diameter ends up being the same.
Beer tastes better upside down.
Old 08-05-2004, 02:43 PM
So what if I already have the bigger rims and already have the tires? Can I still have the gear drive system calibrated to fix this? No, I haven't made it to the shop yet. Waiting until I get some extra money to have these tires/wheels mounted plus the gear box work.
Old 08-05-2004, 04:41 PM
Yes you can have it recalibrated, I was just clairifying the diameter issue.
