Old 08-01-2004, 07:26 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
start w/o clutch
what wire do you disconnect to allow the car(gsx) to be started without using the clutch. i looked and couldnt see any wire or sensor that seemed to be directly connected to the clutch but i did see a green and black wire in a big WHITE harness. the write up said to look for a green and black wire but i just wanted to make sure. before i start disconnecting stuff.
Old 08-01-2004, 07:30 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: start w/o clutch
y do u want it to start with outthe clutch?
even if u did find out how to disconnect it ,it still wouldnt start and u would reck ur starter. there would be too much friction on the motor with it trying to turn itself and the clutch.
correct me if im wrong
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 08-01-2004, 07:38 PM
ill let gsxracer explain...
Old 08-01-2004, 07:43 PM
97_3clipse's Avatar
ya im making a guess
Old 08-01-2004, 08:39 PM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
you are wrong ...lol
[IMG][/IMG]
Old 08-01-2004, 09:41 PM
97_3clipse's Avatar
i was thinking since the clutch was engauged that it would put too much strain on the motor .......o well i was wrong
Old 08-02-2004, 02:17 AM
kjewer1 kjewer1 is offline
AF - Advisor
You absolutely positively do NOT want to have the clutch in when you are cranking the car. There is no oil flow to lubricate the thrust bearing. On a 7 bolt especially, disable the clutch start safety switch. I have a toggle switch on mine, since the track DOES requrie that its in working order. My local track is very strict about safety
On both 1Gs and 2Gs, there are 2 switches on the clutch. One at the "bottom," or when the clutch is to the floor. That is the clutch start safety switch, and its the one you want to disconnect. Simply follow the wires to the connector, and unplug it. Its a pain in the ass upside down on the floor, but it will all make sense once you get an eyeball on it.
And FYI, the other switch, at the "top" of the clutches travel, is to deactivate the cruise control as soon as you touch the clutch pedal. The two connectors arent very far apart, and its easy to mix them up.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-02-2004, 07:42 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
There is actually a video on how to do this, and where the plug is. There are plenty of pictures too, on DSMtuners. It's a white plug above and to the left of the clutch pedal.
On another note, don't make total guess answers. If nobody answered this question right, they might have missed one of the most important steps to prevent crankwalk and bearing wear.
Old 08-03-2004, 06:56 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
So for the last 70,000 miles I have been starting my car wrong. You guys recommend unhooking the sensor and starting the car in neutral with the clutch out???
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-03-2004, 10:10 AM
joemathews's Avatar
joemathews joemathews is offline
Re: Re: start w/o clutch
Yep, that's the idea...I disabled the clutch start switch on mine at 80k. For people who are used to starting with the clutch in, you want to make sure you park the car in neutral if you disconnect the clutch-start switch.
1996 Eagle Talon
Old 08-03-2004, 11:27 AM
coolguycooz coolguycooz is offline
Ok so i did that now everytime i park i have to leave it in neutral before i turn my engine off and stuff? That will prevent wear on it? What if by some slim chance your e-break fails and your car rolls down the street.
How would you make a sensor to set off an alarm when your car is rolling so you can go catch it? lol
Old 08-03-2004, 12:14 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
no only when you start it up put it in neutral. when it is off or you stop you can put it in whatever gear you want, just be sure to drop it in neutral when you start it or you will drive straight thru the garage like i did when i was 10 and didn't know too much about how cars work
Old 08-03-2004, 12:24 PM
george536's Avatar
george536 george536 is offline
my lil bro juss did that a year ago. it was kind of funny since it was my brothers car.
Old 08-03-2004, 09:01 PM
thanks for the help guys... this forum is the cheapest prevention of crankwalk
Old 08-04-2004, 01:16 AM
AF - Advisor
Most people find the habit of stepping on the clutch to start the car hard to break. What I suggest is modify that habit just slightly, put your foot hard on the brake pedal everytime you start teh car instead. The car will NOT move by the starter with the brake applied. It might jump a few inches, but it isnt going too far.
As with anything else, safety first.A guy at a local track accidentally started the race gas (had no nuetral start switch) and killed his duaghter. That is why my track now requires it. We want to rpevent crankwalk, but we dont want anyone to get hurt either. Jsut get int he habit of using the brake pedal, AND putting it in nuetral before starting.
Kevin Jewer
