Old 08-01-2004, 07:02 PM
azmouse azmouse is offline
99 s-10 blazer engine codes
Does anyone know what engine trouble code p1870 is ? It has to do with the powertrain, but i dont know what specifically.
Old 08-01-2004, 09:47 PM
ajk114 ajk114 is offline
A P1870 code means the transmission is seeing a slip condition. Sometimes it points to the TCC clutch not working properly. Sounds like the transmission needs to come out. See if you can get hold of a GM diagnostic chart for this code and it will make more sense to you.
CIRCUIT DESCRIPTION:
The Powertrain Control Module (PCM) monitors the Torque Converter Clutch (TCC) slip by calculating the difference between the engine speed and the transmission output shaft speed. When the PCM detects an excessive amount of slip when the TCC is engaged, then DTC P1870 sets. DTC P1870 is a type A DTC.
CONDITIONS FOR SETTING THE DTC:
No Throttle Position (TP) DTCs P0122 or P0123
No Vehicle Speed Sensor (VSS) DTC P0502
No 1-2 solenoid performance DTC P0751
No 1-2 solenoid electrical DTC P0753
No 2-3 solenoid performance DTC P0756
No 2-3 solenoid electrical DTC P0758
No TCC Pulse Width Modulation (PWM) solenoid electrical DTC P1860
No TCC enable solenoid electrical DTC P1864
The engine speed is greater than 500 RPM for 5 seconds.
Not in fuel shut off
The throttle angle is 9.5-35%.
The transmission is not in 1st gear.
The transmission gear range is D4.
The transmission fluid temperature is 20-1300C (68-2660F).
The engine torque is 70-270N.m (50-200 ft lbs.).
The Manifold Absolute Pressure (MAP) is 0-105 kPa (0-15 psi).
The TCC is commanded ON and at maximum apply for 5 seconds.
The TCC slip is greater than 200 RPM for 8 seconds.
The above conditions must occur three times with the TCC commanded OFF between each occurrence.
ACTION TAKEN WHEN THE DTC SETS:
The PCM inhibits TCC operation.
The PCM inhibits 4th gear, if the transmission is in the hot mode.
The PCM illuminates the Malfunction Indicator Lamp (MIL).
CONDITIONS FOR CLEARING THE MIL/DTC:
The PCM turns OFF the MIL after three consecutive ignition cycles without a failure reported.
A scan tool can clear the DTC from the PCM history. The PCM clears the DTC from the PCM history if the vehicle completes 40 warm-up cycles without a failure reported.
The PCM cancels the DTC default actions when the fault no longer exists and the ignition is OFF long enough in order to power down the PCM.
DIAGNOSTIC AIDS:
Ensure that the vehicle's final drive ratio matches the PCM's calibration.
Ensure that the transmission will shift through all four gears with the gear select lever in the D4 range.
Good luck!
Old 08-03-2004, 12:16 AM
Thanks for the info, the tranny did seem to be slipping a couple of weeks ago but it has been fine lately. The service engine soon light turned was off the past two weeks only to light up again the other day, I'll probably take it in to the dealer and see what they say. I just thought about this, about a month ago my local auto part store was offering a free top off on all fluids and the guy threw in a quart of tranny fluid saying it was low, I had just checked a week or so prior and thought it was good. Could over filling cause this problem code?
Old 08-03-2004, 11:37 PM
Slightly overfilled is usually not a problem but severely overfilled causes the oil to be churned with resulting air (foaming) in the oil. This severly impairs torque convertor efficiency and overall lubrication and performance and yes, could be the cause of the slip. If the trans had no problems, shifted smoothly through all ranges prior to the "top off" then correcting the oil level would be the place to start. Check out the post entitled "hard 1-2 shift". Jeremy-WI posts some great information there. Careful with the dealer, their mission is to relieve us of as much cash as possible. Willing to bet they will recommend a new valve body. Pays to shop around.
