Old 08-01-2004, 06:27 PM
dukeofchurchill dukeofchurchill is offline
Send a message via AIM to dukeofchurchill
Question 96 C-1500 Daytime Running Lights
The running lights on my truck don't come on. Any ideas about what the problem is? All the other lights are fine.
Old 08-01-2004, 09:25 PM
YBNRML YBNRML is offline
Send a message via Yahoo to YBNRML
Re: 96 C-1500 Daytime Running Lights
I have a 96 z71 and mine does not come on. I did not yet check the obvious, the bulbs being burnt out. My reverse lights dont come on and I have changed the bulbs on them.
Old 08-01-2004, 09:26 PM
I have not checked. But I am thinking that I have a fuse out.
Old 08-07-2004, 04:35 PM
haleybarb haleybarb is offline
yah, i have the same prob. they were working and now they aren't. replaced the computer card (80 bucks later)b/c the mech told me that the relay was ok. (had already checked the fuse = OK). am thinking now that maybe its both the card and the realy???
Old 08-07-2004, 11:39 PM
TweakedGM TweakedGM is offline
they are bad for DRL diode. It is a finned box about 2" high and about 1 1/2" wide. It is under your dash on the drivers side right of the steering column about knee height which is where the steel tube is the diode is on the tube.To get it off to replace you need 10mm wrench and a pair pliers then slide it out.
Old 08-08-2004, 08:58 AM
Thanks I will check it out
Old 08-08-2004, 12:10 PM
is the drl diode black colored??
Old 08-08-2004, 03:37 PM
yes it has a plug on the top with two wires.
Old 08-08-2004, 04:06 PM
hmmmmm. (thoughtfully rubbing chin) i geuss i'll have to have another look too.
Old 08-08-2004, 04:15 PM
haleybarb what computer card did you get replaced
Old 08-08-2004, 06:51 PM
the one for the drl. its a flat, silver (if i remember correct) thingy under the dash between the steerin column and the drivers door. a mech at work knew about it from previous experience (at a dealership he worked at before he came to the airport authority)
Old 08-11-2004, 12:30 PM
PonceDeLeon187 PonceDeLeon187 is offline
As far as the reverse lights go, try replacing the ciruit board on you tail lights. Probably the most annoying ass problem with Chevy's around that time. Its about $35 at Oreily's.
Old 08-11-2004, 01:15 PM
I changed the rear board (approx. $35.00) and they still dont work. Confused!!!!!!!!!!
Old 08-12-2004, 02:39 AM
have you ever looked under the back of the truck on the drivers side.there is a plug for the tail lights some of the wires might have broke. put a test light to the wires with reverse in gear.neutral safety switch or just park the back to a wall at night and go though the gears and see if the light comes on.
