Old 08-01-2004, 05:59 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
axle
I went out and purchased a new front axle (due to the fact my cv joint was shot) and went to install it but the splines would not match up to those off the tranny(it would not go in for sh$^). maybe they gave me the wrong part. on reciept it says L4 and was wondering if there is an L4 tranny? is there a special(tool) to get it back in?
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 08-01-2004, 06:03 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: axle
what kind tranny you putting them in i know my 90 crx si came with a L3 maybe thats what you might need bro
Old 08-01-2004, 06:07 PM
Jos4DCivic's Avatar
it is an L3 as well. should the axle just slide right in or do you got to play wit it a little to get it to go in?
91 Hatch SI
Finally painted!!!
Old 08-01-2004, 06:12 PM
Re: axle
well its only tought as it was to get out dont bang it in then you screw yourself...i havent put mine in but plan to do so in like 5 days when rest bolts get here i was missing on my motor after throwing a rod bearing...but just turn the axle till you feel it lock in with the splines then tap it in from there...but if it seems really hard then gotta be wrong axle....easiest way to tell compare it to the old one
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: axle
They must have given you the wrong one because all the 4th gen Civics have the same inner joint splines.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-01-2004, 06:38 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Where is it hard to go in? At the hub or the tranny? It should slide into the hub fairly easy but when putting it into the tranny, you need to put some force behind it and shove it in there pretty hard. But like feagle said, compare it to the old one if you havent already taken that in for a core. Or just call the place you got it from and ask them for the correct part number and see if yours is the same.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 08-01-2004, 06:57 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: axle
yeah..its always a bitch to get taht snapclip to go in..just gotta keep rotating it back and forth while pushing hard..its a pita.
SOLD!
Old 08-01-2004, 07:44 PM
Jos4DCivic's Avatar
im trying to get it into tranny. i returned old one for core .it does engage but just the end of the axle about till little ring on end then wont go in anymore. splines look just barely to tall after where it engages.
91 Hatch SI
Finally painted!!!
Old 08-01-2004, 08:26 PM
Re: axle
well you can always pull other one out for last resort and match it up with the one they gave you find out if its the right one...if you do take it apart member bigger axle goes on drivers side
Old 08-02-2004, 03:11 AM
smokeymicpot smokeymicpot is offline
Send a message via AIM to smokeymicpot
man i got new ones for my car and it was a bit+h to put in i had to slam it in and the wheels were just as hard i put the rotors back on and put the axle in and than hit the rotor tell it was throw enough to get the bolt on
