Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 08-01-2004, 02:52 PM
LostonZC LostonZC is offline
removing 2002 Jetta door panels
Does anyone know how to remove the driver side door panel. My window is off the tracks and I know its going to rain soon. Please help!
Old 09-16-2004, 06:51 PM
bkoop90 bkoop90 is offline
Re: removing 2002 Jetta door panels
Take it to a dealer. I was on a trip to Chicago and the window sounded as if it went off track. Had to go to a dealer and they told me that there was a service bulletin out stating that the clips holding the cable were made of plastice. My warrenty was expired by about 12,000, but he replaced it under the warrenty any way because he believed it would be recalled.
Old 05-06-2005, 09:18 AM
dom26oo dom26oo is offline
Removing the window crank is really easy. Point the crank down twards the ground. Then slide your finger behind the crank arm from underneath. Then push up on the colar between the crank arm and the door. Or you can push down, just make sure the handel is pointing down. Once the handel is off there are 2 or 3 screws at the bottom of the door you will have to feel them out and unscrew. Then gently run your fingers behind the door panel and pop any clips that may be there. Its simple once you know how!!
Old 05-14-2005, 08:16 PM
bigblackone bigblackone is offline
definately take it to the dealer .. there is a tsb to replace the faulty window regulators ...
