Old 08-01-2004, 02:20 PM
Crashhopper Crashhopper is offline
Question 1989 Chevy Suburban
I got in my Suburban the other day and when I cranked it the starter clicked and turned once then the dash lights, radio, door locks, windows, and turn signals stopped working. I turned the key a few more times and it acts like there isn't any power, but the interior lights and head lights still come on. When I turn the key to accessery power the radio will work, but using the turn signal switch causes the radio to loose power. The battery is putting out 12 volts and switching it out with the battery in my Bronco didn't change anything. I checked my fuse block and nothing was burned out. The circuit breakers showed continuity even when I turned the key to see if they were tripping. When turn the key it seemed to cut power to the fuse block. I ohmed out the start switch and everything works as advertised. Now I am pulling the wiring harness in the engine compartment and so far there are no broken wires or shorts I have seen, but will ohm out the wires once I finish removing it. Has anyone had a similar problem and how did you fix it?
Old 12-12-2004, 05:53 PM
kirchc kirchc is offline
Re: 1989 Chevy Suburban
It could be your fuseable link that should be on the passenger side of the firewall under the hood. Your local chevy dealer can show you the wiring diagrams to see the exact location. I had a 90 chevy that had similar problems and this is what it turned out to be - good luck
Old 08-22-2007, 10:36 PM
docwan's Avatar
docwan docwan is offline
Does anyone have a wiring diagram for a 1980 Chevy Suburban motor ? I'm looking for the under hood wiring diagram.
Please reply to:
[email protected]
Thank you
Old 08-22-2007, 10:50 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Please reply to:
[email protected]
Thank you
Please start a new thread, versus resurrecting a thread that hasn't been posted in for 3 years.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
