I rolled my jeep
Have any of you guys rolled your jeeps? I did it to mine yesterday and it won't start. I pulled out the spark plugs and cranked my engine to get all of the oil out of the cylinders (and there was a lot of it). I also disconnected my battery to reset the fuel pump. Do any of you know if there's something esle I should do to get it to run. My brother rolled his cherokee a lot worse than I did and it started right up afterwards. Everything seems to be OK with the engine. I don't know what's wrong.
Re: I rolled my jeep
What year Jeep? If it has an inertial switch in it, good chance it is tripped. Look around your kick panels or under the dash. That will keep your fuel pump from working. to check this theory, put a little gas down the throttle body and turn it over. If it fires then you know everything else is working but the fuel supply.
