Old 08-01-2004, 12:19 PM
robinjohnston34@ho robinjohnston34@ho is offline
Unhappy 1992 ford taurus i need help
my 92 3.8 taurus is overheating. i have replaced the water pump the radiator and the thermostat. still overheating. can someone please help!!!!!!!!!!!!
Old 08-01-2004, 10:31 PM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
Re: 1992 ford taurus overheating
Did you "burp" the cooling system after all that, to make sure you got all the air out? Are your head gaskets ok?
Also, you'll need to pull any codes stored by the computer.
How much work are you able to do yourself? To pull the codes, check out http://www.dalidesign.com/hbook/eectest.html
Hope this helps.
Old 08-02-2004, 08:26 PM
Re: 1992 ford taurus i need help
thanks for the tip we burped the radiator and now the fan is kicking on but it is not cooling down the engine. if you have any more suggestions i would appreciate them.
Old 08-02-2004, 09:25 PM
Car Pal Car Pal is offline
ck. for a restriction in the bypass hose near the altenator.
unplug the ect sensor near the t-stat. the fan should come on high speed.
Old 08-04-2004, 05:50 AM
sahib sahib is offline
Is the radiator cap the correct one for the vehicle and is it in good shape? How badly is it overheating? What were the circumstances leading up to this? Did it just start one day or did it gradually start getting hottter and hotter? Under what conditions does it overheat?
Old 08-04-2004, 09:36 AM
yes the radiator cap is the right one for the car the car gets hotter and hotter until it boils. and it just started happening one day
Old 08-05-2004, 10:17 AM
Willyum Willyum is offline
robin,
Dan in WA gave you a good clue. Older 3.8 engines have had problems with headgaskets.
Old 08-08-2004, 12:18 PM
how do you tell if your head gasket is blown?
