Old 08-01-2004, 10:57 AM
SpeedDemon101's Avatar
SpeedDemon101 SpeedDemon101 is offline
Send a message via AIM to SpeedDemon101
89 lesabre performance?
Is there any sort of performance products out there for a 89 lesabre?
Old 08-02-2004, 10:14 AM
redly1 redly1 is offline
Re: 89 lesabre performance?
You could always start with a K&N filter...I've never tried one, but some guys swear by them. If you do that, you may want to do a "cold air box" mod. My understanding is that you increase the size and change the position of the inlet to the air filter box.
From there, I think it gets spendy
Old 08-02-2004, 11:23 AM
well ive already got the k&n air filter, platinum plugs, and took the catty off. I cant find anywhere that has any sort of cold air induction system for the series 1 3800s
Old 08-02-2004, 11:54 AM
I was looking at the air box on my car (91). It looks like it would be a very easy DIY mod with a hole saw, black poly 4" pipe (cheap stuff for drains at home depot). I would creat a flange and mount a 45degree bend downward at about ~7oclock angle and pull cold air coming in from under the car. Make sure to use a metal screen on the inlet, so you don't suck in too many bugs/rocks.
You're gonna have to clean your K&N at least monthly, but this will really open up the inlet air
other than that, I haven't come across a whole lot of parts for series 1 Vin C (88-91) 3800 engines
I'm thinking of fabrication one for the heck of it. I can't imagine the parts would cost more than $10. Wanna be my guinie pig??
Old 08-02-2004, 09:18 PM
i found a guy online that did something of that sort but he place the k&n cone filter into a hole in the inner fender. he reported results of better performance but he lost 1-2 mpg.
Old 08-02-2004, 10:09 PM
ahh
I'm pulling this out of my ass...so here goes
I would guess that the computer compensates for the extra air flow by increasing the amount of fuel going into the mixture, thus the loss of MPG. The extra power is the result of more air and fuel being injected into the cylinder (think of it this way, more TNT, bigger explosion)
I don't fully understand the benefits/pitfalls of running your fuel mixture lean or rich (lean = higher % or air than "normal", rich = higher percentage of fuel, IIRC) I wonder what a combination of the "cold air box and K&N" mod and the "10%+ HP boost" mod you see on ebay would result in.
IIRC, the mod from ebay alters what the ECM seems as a fuel mixture ratio by installing a resistor divider circuit on the O2 sensor (??)
here is an example of the mod on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...category=33597
any way you look at it, these are pretty cheap mods that are easily reversable if they don't work. ENJOY!!
