Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 08-01-2004, 10:21 AM
o0Quicksilver0o's Avatar
o0Quicksilver0o o0Quicksilver0o is offline
Send a message via AIM to o0Quicksilver0o Send a message via MSN to o0Quicksilver0o
fmu and fuel press reg q's
how does a fuel pressure regulator and a fuel managment unit work and what do they do exactly?
My Current Best 1/4 Mile: 16.832 seconds
My car site
Old 08-02-2004, 05:36 PM
boosted331 boosted331 is offline
Re: fmu and fuel press reg q's
A fuel pressure regulator does just what it sounds like, regulates fuel pressure. An FMU boosts fuel pressure in relation to boost (4:1, 8:1, 10:1, 12:1 ratios are most common) to add more fuel to the car to make up for the turbocharger or supercharger. Some FPR's will also increase fuel pressure in relation to boost, but they do it in a 1:1 ratio and are typically used for carb'ed cars running a blow-thru setup, you need to raise the fuel pressure 1:1 to compensate for the boost pressure trying to force the fuel back into the bowls.
Old 08-02-2004, 07:10 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if you plan on boosting i would run more of a management unit then just a fmu because it only controls fuel, it doesnt control timing.
also if you get bigger injectors a fpr really isnt needed, it is only really needed if your injectors arent sized right and you need more fuel.
Team Lonely Drivers
Old 08-03-2004, 09:51 AM
chixSI's Avatar
chixSI chixSI is offline
Send a message via AIM to chixSI
i have a question and maybe you guys can help me. I made a thread on this but got no help. When i drive my car for about 15-20 minutes my car starts to ideal at 1500 RPMs. Then when i'm at a complete stop and start off in 1st gear my car has the major "hick-ups" A friend told me it's because my ECU is reading boost and that's what causes the "hick-ups" so i was told by him to take out the e-manage, put on a bracket for the map sensor, get FMU, and get release pressure valves so it releases the boost. I understand what he is saying, but it just doesn't sound right! what do you guys think? have you heard of this and do you think it would help with my "hick-ups"?
chixSI a.k.a *jennie*
***Never Drive Faster Then Your Guardian Angel can Fly!!!***
www.teckademicseast.com
www.teckademics.com
www.dtmpower.net
www.motivonline.com
www.importvelocity.org
: TURBO is now in...
Old 08-03-2004, 11:06 AM
So what exactly does regulating mean. Thats what i am looking for.
My car site
