Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 07-31-2004, 08:33 PM
laichzeit laichzeit is offline
Check Engine light problem
Hi there,
I'm new to this forum and I need some help.
I own a 1993 Subaru Impreza Wrx Ra
Recently the Check Engine light has come on and won't turn off. I've checked oil and water. It used to come on when the engine was cold and turn off when the temperature got up to half way. Now it just stays on the whole time. There is no difference in the driving of the car so if someone cold help me out it would be great
cheers
Old 08-04-2004, 04:21 PM
aumnsoccer aumnsoccer is offline
Send a message via AIM to aumnsoccer
Re: Check Engine light problem
did you get gas recently...if you don't tighted the cap enough it will set off the check engine light.
Old 08-04-2004, 04:35 PM
moger21 moger21 is offline
Send a message via AIM to moger21 Send a message via MSN to moger21
yeah i did that once an i couldnt figure out why the check engine light came on, i checked the book and it said that could be a reason, so i went and tighten it, and it only took 5 days for the damn thing to go off lol. now i make sure i tighten that thing real good :-)
Old 08-04-2004, 10:40 PM
Thanks for the help, I did a diagnostic check and it turns out it was the Water temp sensor. so I'm getting that replaced. That should do the trick
