Tibby01's LED Stuff
with the stock cluster, i can do this....
any color needles(even mix and match diff. colors with diff. needles) any color faces/tick marks(i can mix colors on these too, to a certain extent) any color indicator lights(whatever colors you want) i can do each one of those for 40 dollars, except the tick marks. i gotta make those 50. if you got everything, id prolly lower the price down a bit too. if you have white face gauges, i can definately do the needles the same, but i dont think i'd be able to change the color of the faces without being very hesistant about messing up someones faces that they paid for. it depends on the faces as far as the indicator lights go, but it should work for mos tof them. i know i could change the color of the indicator lights with the sr white face gauges. then with thte other stuff, i can put whatever color led into whatever switch you want. the only things left red in my car are the hazard switch and courtesy lights, which if all things go well, will be changing soon. because everything is different, write me an email with exactly what you want and ill figure out a price for it. [email protected] http://rdtiburon.com/index.php?name=...iewtopic&t=133 |
looks nice buddy -- I'll have to keep you in mind for when I'm ready to start twinking.
![]() hey nisco, you wanna try something out? id give ya a deal since you would be the first gk. |
Re: Tibby01's LED Stuff
ohh i love it
... but i have no experience with electronics..or lighting... maybe ill order a set and have a shop do them for me |
no dude, you dont order a set. if you send me the cluster i can do everything for you. then id just send it back and all you would have to do would be to plug it in.
that helps nisco out big time! |
what about the wiring to the ground wire and brake light? does he have to do that himself also? i don't see how you are powering those without outside sources of power..
ground wire and brake light? huh?
using webtech, i can find a schematic for the gauge cluster, and then tap into the pcb(printed ciruit board) where there is power for the illuminations. its just leds, so almost no power at all. A LOT less than the stock bulbs. nisco, if you want to work something out, email me at the addy i put in the first post. |
