Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 07-31-2004, 05:46 PM
jdorfman jdorfman is offline
2001 Sebring Front Right Whine
I have 2001 Sebring LX with 36000Km on it. This week I took it on a road trip up north and a medium pitch whine started to appear at the front right...
It only appears above 40kph and if you break it disappears below ~20kph...
The sound is not always present... 2 days ago it appeared when ever I was above 50kph regardless... and yesterday (the day I took it to the dealer..) it did not appear at all... therefore 'no fault found'. Today... it is again persistent..
Some more clues:
Disengaging the engine has no effect on the sound (going to neutral)..
Increased speed increases the volume and the pitch only slightly..
Decreasing speed does not decrease the volume until ~20kph and then it rapidly decreases to 0 audible volume...
Today I had a passenger in the the car.. yesterday I did not..
Today and 2 days before were very humid and yesterday was not..
As a side note... yesterday the oil was changed and 2 new tires were put on the car.. and rotated to the front.. obviously the act of removing the wheel and replacing the wheel did not stop the sound..
Please Assist...
Old 08-01-2004, 10:11 PM
Oldengineer Oldengineer is offline
Check your front brakes to see if they're worn out. The sound you're hearing may be the wear indicator dragging on the rotor.
Old 08-09-2004, 06:43 AM
notamechanic notamechanic is offline
It's probably the wheel bearings going bad. Mine went bad around the same mileage on both sides.
Old 08-18-2004, 03:37 PM
PashaDNN's Avatar
PashaDNN PashaDNN is offline
Send a message via ICQ to PashaDNN Send a message via MSN to PashaDNN
Re: 2001 Sebring Front Right Whine
yep, it's the wheel bearings
"The thinner the TV, the better the TV, it's just straight up fact." -Dennis
Old 12-22-2004, 12:19 PM
gettelsl gettelsl is offline
It is the wheel bearings...had the smae thing happen to mine and only seems to wear out inthe front passenger side...
Old 12-03-2005, 05:29 PM
jlfrench jlfrench is offline
what if the whine sounds like a squeak, and is present when stationary and turning the wheel?
Old 01-13-2006, 11:31 AM
king80vette king80vette is offline
I need to replace these on a friend’s car. Is this something a shade tree mechanic can do with normal tools? Do I have to get into the CV joints?
Steve
Old 03-07-2006, 06:36 AM
joe8918's Avatar
joe8918 joe8918 is offline
It's the hub assembly...I've replaced both front sides on mine. Does it sound like there's more friction when you move your steering wheel from side-to-side at a higher speed (> 50mph)?
