Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-31-2004, 05:19 PM
cksilent cksilent is offline
Talking 98 civic problems please help
i really hope that someone can help me out on this on this is my first time using this web site. alright this is my sanerio i have a 98 honda civic automatic. my car was runnning good. about a week ago i noticed that when i would put it into drive or reverse the rpms would drop really low. when im drivin it and i come to a stop the rpms drop down to 0 or below that line and some times dies. if it doesnt die the rpms go up a lil and down while im stopped. i replaced the battery and spark plugs and i cant figure it out i cleaned the filter also. i hope someone can help me on this one
Old 08-05-2004, 04:17 AM
Dankster18 Dankster18 is offline
Send a message via AIM to Dankster18
Re: 98 civic problems please help
maybe you have a slight vacuum leak or you may need to clean out your fuel injectors for this one
jsut throw in some fuel injector cleaner in the tank and run it a lil if it still does it. it may be the vacuum leak but if not i recomend you get your car diagnosed at your local mechanic to find out wut the deal is
Old 08-06-2004, 04:00 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
probably fuel injectors needs to be cleaned, could be fuel filter also. like dankster said throw some injector cleaner and see if that solves the problem
Team Lonely Drivers
